It is currently Fri Oct 30, 2026 12:51 am
Vehicle: zook
Post Posted: Mon Jun 28, 2010 9:45 am
Where can I get a crown wheel and pinion for the rear diff? How much should I expect to pay?
Also, on a scale of "changing a tyre" to "replacing a clutch", how difficult is the task to replace these parts?
In the meantime, Crunchy gravelly crunch!
Post Posted: Mon Jun 28, 2010 9:55 am
its harder than changing a clutch.
get some one who knows how to set up a diff to do it.
Vehicle: '96 LWB trayback
Post Posted: Mon Jun 28, 2010 12:05 pm
Why not just grab an entire jimny centre from a wreckers and swap it in?
The cost for an entire centre is ~$250 last time I checked.
A new R/P costs more, plus you have the associated costs of new pinion seal, crush sleeve and having the backlash set professionally.
Install of an entire centre is easy, and only takes a couple of hours.
Post Posted: Mon Jun 28, 2010 12:30 pm
Get a complete centre from the wreckers.
shop around on price.
Make sure you get the same ratio.
This way you can fit it yourself with basic hand tools. If you remove the R&P's you will need to lap the diff and set backlash etc. Much more specialized.
Pete
Vehicle: zook
Post Posted: Tue Jun 29, 2010 8:49 am
Good advice, Thanks fellas.
will let you know how i get on if I find a new (used) diff center.
Users browsing this forum: No registered users and 163 guests
