It is currently Tue Oct 27, 2026 11:37 am
Post Posted: Tue Jun 29, 2010 7:39 am
I was wondering instead of mukin around with the looms and switches if you can just run a wire from your high beam to the actual driving light will this work?
Post Posted: Tue Jun 29, 2010 7:40 am
if by 'work' you mean 'set fire to my headlight wiring', then yes. It will work. :P
You need clean battery power switched via relay. Best to do it properly. :wink:
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Tue Jun 29, 2010 7:53 am
A set of driving lights will draw more current than the standard loom is designed to handle.
It really is necessary to put it through a relay, since you are going to have to do this you could also put the headlights through relays and give them a bit of a boost too.
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
x2 use the headlight high beam switch as the switch for the relay and run fused 12v from the battery(or from a fuse block that has and ignition switched relay supplying its power) that way when you turn of the ignition the spotties wont stay on...just safer..unless you want them on while the car is off.....
Coily GTI Turbo...thats right its a coily!!
Users browsing this forum: No registered users and 212 guests
