| g16b heads? https://auszookers.com/forum/viewtopic.php?f=5&t=13151 |
| Author: | Brett [ Tue Jun 29, 2010 9:02 am ] |
| Post subject: | g16b heads? |
i picked up a vitara that is ment to have a blown head gasket. my question is do they blow gaskets much, warp the heads or should i be looking for a crack in the head and where? |
| Author: | want33s [ Tue Jun 29, 2010 9:27 am ] |
| Post subject: | Re: g16b heads? |
Brett wrote: i picked up a vitara that is ment to have a blown head gasket.
my question is do they blow gaskets much, warp the heads or should i be looking for a crack in the head and where? ha ha ha ha... G16B heads are absolute crap... I went through three before buying a BRAND NEW BARE HEAD ..... |
| Author: | Damo [ Tue Jun 29, 2010 9:33 am ] |
Take off the rocker cover and there are some welch plugs under the rocker shaft (3 if I remember correctly). They crack between those welch plugs. |
| Author: | Brett [ Tue Jun 29, 2010 10:07 am ] |
Damo wrote: Take off the rocker cover and there are some welch plugs under the rocker shaft (3 if I remember correctly). They crack between those welch plugs.
hopefully is this ha ha ha ha... G16B heads are absolute crap... I went through three before buying a BRAND NEW BARE HEAD ..... what did it cost you? i'm hoping to have it done so i can go to stockton next weekend. |
| Author: | appsie [ Tue Jun 29, 2010 10:54 am ] |
if the head is cracked then i doubt youll be going anywhere by next weekend. could be worse,the block could have a slight crack |
| Author: | Brett [ Tue Jun 29, 2010 10:58 am ] |
just depends on how quick the postie is if its cracked. swapping heads won't take long. |
| Author: | want33s [ Tue Jun 29, 2010 10:35 pm ] |
Bare head was $550... It's hard to see but there are cracks around the little welsch plug.
This was the 2nd head and the crack is a little more obvious.
| Author: | JrZook [ Tue Jun 29, 2010 11:18 pm ] |
Same head and same issues as the G13BB jimny engine. Have fun setting the tappets |
| Author: | BlueSuzy [ Wed Jun 30, 2010 12:22 am ] |
Err.. Mine sounds like a diesel...Tappets? |
| Author: | Brett [ Mon Jul 05, 2010 7:50 am ] |
well i finally got the head off this arvo and its cracked so i'm about to see where i can find a new head from. on a side note the suzuki engineers must hate the mechanics or they are kids with small hands! that was the hardest head i have had to pull off. |
