It is currently Tue Oct 27, 2026 6:46 pm
Post Posted: Tue Jun 29, 2010 9:47 am
hey all found out why my speedo is not working it has broken were it goes in to the t-case broke the cable. how hard is it to replace and how much would they be? or would it be easier to just the the navman for the speedo ?
2''lift 31's twin locked & 6.5s
Post Posted: Tue Jun 29, 2010 9:52 am
http://www.suzistore.com.au/shopexd.asp?id=688
Cheap!! :P :P
Not to much fun to fit if it's never been replaced before, that run between the heater box & the fire wall.
Vehicle: 03 Jimny
Post Posted: Tue Jun 29, 2010 9:54 am
i just replaced mine 2 days ago got the cable for 25 dollars i could put it in the original spot which is behind the fan blower in ur dash so i had to relocate it, it is quite easy to replace
Post Posted: Tue Jun 29, 2010 9:55 am
ok kool
Post Posted: Tue Jun 29, 2010 11:29 pm
simple as to swap over i done mine in like 5 mins hardest part is getting it into the back of the speedo.
Post Posted: Tue Jun 29, 2010 11:40 pm
Yeah as others said the bitch part is putting it into the dash. I removed the centre console and pushed it in that way.
Otherwise manual says to drop the steering tube down... I couldnt get the hex bolts undone so thats when I thought of getting the grinder and hacking the car into 50c size pieces. Then some one said "hey what about undoing these 4 bolts on the centre console"
Grinder was used that day... :roll:
255 characters
Users browsing this forum: No registered users and 296 guests
