It is currently Wed Oct 28, 2026 2:30 pm
Post Posted: Sat Jul 03, 2010 10:54 am
Hey
Just wondering if a 1.3l cylinder head will fit on a 1l block
thanks for any help
Macca.
NO.
Post Posted: Sat Jul 03, 2010 11:04 am
thanks mate :D
Post Posted: Sat Jul 03, 2010 11:09 am
Tonka4 wrote:
thanks mate :D
No worry's.. :P
Post Posted: Sat Jul 03, 2010 11:41 am
Just FYI, the 1.0 is a different engine series to the 1.3.
The 1.0 is an F series (F10A). The 1.3 is a G series (G13A, G13BA etc). The G series heads can be interchanged between blocks (to a degree anyway, I know of a few hybrid motors). I assume the F series are similar.
But being different series motors, you can't mix and match bits.
I want my old sig back :(
Post Posted: Sat Jul 03, 2010 11:50 am
:P
Suzuki G10a :D
http://4.bp.blogspot.com/_YwRYjoITGYc/SA53wwTQvhI/AAAAAAAAAG4/P5VFFOkg_Nk/s1600-h/%E3%82%B3%E3%82%B9%E3%82%BF%E3%83%AA%E3%82%AB+005.jpg
and G10 turbo :twisted:
Post Posted: Sat Jul 03, 2010 11:55 am
Yes Pete, but not in an Aus delivered zook :P
Post Posted: Sat Jul 03, 2010 12:15 pm
meh.
:P
They've been flowing into the country for years. Not so much the last 10, but before that they were everywhere :D
Derek at suzuisport Lawnton has a built G10 turbo that he used to run in his buggy. It made some silly HP too if I recall. :D
Post Posted: Sat Jul 03, 2010 10:05 pm
That's an interesting motor but it looks like it would be a massive PITA to get into a sierra.
Post Posted: Sat Jul 03, 2010 11:20 pm
[quote="Gwagensteve]
Steve.[/quote]
same amount of drama as the F6 or K6 motors I recon. :?
Post Posted: Sat Jul 03, 2010 11:24 pm
Are the internals on a f10 anywhere near strong enough for a turbo with just a little huff?
Post Posted: Sat Jul 03, 2010 11:46 pm
you'de get away with a 4-5psi intercooled setup IF your motor was in good condition.
But you'de be lucky to see a 30% power gain which would still have you at factory 1.3L power levels or less.
Post Posted: Sun Jul 04, 2010 1:32 am
Suzuki G10a
The G10 is a three banger, so the 1.3 head doesn't fit that either
Post Posted: Sun Jul 04, 2010 1:37 am
It shouldn't be significantly more difficult than swapping a DOHC G13B from a Swift in - the biggest problem would most likely be the distributor to firewall clearance - the tranny bolt pattern is the same as the 1.3, you will have to fab engine mounts, do your own intake & exhaust plumbing, and of course the ECU and wiring harness
Users browsing this forum: No registered users and 333 guests
