It is currently Thu Oct 29, 2026 5:20 pm
Post Posted: Sun Jul 04, 2010 1:21 pm
i've been staring at the car for to long now trying work the wiring out so is any one confident enough to do it for me i have all the wiring harness and relays, ecu. The g16b im using is the motor that has the coil inside the distributor and a mitsubishi computer (which i need one if anyone has one)running the motor
please help to put another lwb on the road :cry: :lol:
Post Posted: Sun Jul 04, 2010 11:53 pm
Sounds like and x90 engine. I have one in my Sierra, and as far as I can tell the wiring is slightly different to Vit 16v engines.
Why do you need a ECU???
Post Posted: Mon Jul 05, 2010 12:33 am
You say you have the ECU but then you say you need the computer??????????????
ECU IS the computer....
Try Killalux..... http://stores.ebay.com.au/id=96583767
Post Posted: Mon Jul 05, 2010 1:36 am
i have the ecu but the plug isnt the best so i,ve had to wire it direct to circuit board ill give killer lux a go
Post Posted: Mon Jul 05, 2010 1:43 am
8O
pics?
What model is the ECU? Will have a number on it like this:
Post Posted: Mon Jul 05, 2010 2:56 am
Post Posted: Mon Jul 05, 2010 3:10 am
Your connectors look ok in that pic???
Post Posted: Mon Jul 05, 2010 3:09 pm
its where the yellow wire is solded the pins that go to the circuit board are corroded and have came off the board
Users browsing this forum: Google [Bot] and 582 guests
