https://auszookers.com/forum/
need wiring help g16b to sierra
https://auszookers.com/forum/viewtopic.php?f=5&t=13283
Author:  bazook [ Sun Jul 04, 2010 1:21 pm ]
Post subject:  need wiring help g16b to sierra
i've been staring at the car for to long now trying work the wiring out so is any one confident enough to do it for me i have all the wiring harness and relays, ecu. The g16b im using is the motor that has the coil inside the distributor and a mitsubishi computer (which i need one if anyone has one)running the motor
please help to put another lwb on the road :cry: :lol:
Author:  Damo [ Sun Jul 04, 2010 11:53 pm ]
Post subject:  Re: need wiring help g16b to sierra
Sounds like and x90 engine. I have one in my Sierra, and as far as I can tell the wiring is slightly different to Vit 16v engines.
Why do you need a ECU???
Author:  want33s [ Mon Jul 05, 2010 12:33 am ]
You say you have the ECU but then you say you need the computer??????????????
ECU IS the computer....
Try Killalux..... http://stores.ebay.com.au/id=96583767
Author:  bazook [ Mon Jul 05, 2010 1:36 am ]
i have the ecu but the plug isnt the best so i,ve had to wire it direct to circuit board ill give killer lux a go
Author:  Damo [ Mon Jul 05, 2010 1:43 am ]
8O
pics?
What model is the ECU? Will have a number on it like this:
Author:  bazook [ Mon Jul 05, 2010 2:56 am ]
Author:  Damo [ Mon Jul 05, 2010 3:10 am ]
Your connectors look ok in that pic???
Author:  bazook [ Mon Jul 05, 2010 3:09 pm ]
its where the yellow wire is solded the pins that go to the circuit board are corroded and have came off the board
