It is currently Wed Oct 28, 2026 12:09 am
Post Posted: Mon Jul 05, 2010 12:19 am
hey all
just wandering if anyone knows how to get my sierras transfer case out of 4h as it got stuck after pulling the lever out and putting it back in it wont move and the selector bush is fine :(
any advise will be great thanks trent
does a 1990 selector shifter for the transfer case fit into a 1994 transfer case
1990 Sierra, 31s and a work in progress
Post Posted: Mon Jul 05, 2010 12:28 am
You can't just shove the level back in, you need to line up the gates properly, how did you put it back in?
I want my old sig back :(
Post Posted: Mon Jul 05, 2010 12:30 am
if the gates had moved how would i realine them
Post Posted: Mon Jul 05, 2010 12:56 am
With a large screwdriver.
Post Posted: Mon Jul 05, 2010 1:05 am
thanks fordem is this fairly easy
Post Posted: Mon Jul 05, 2010 1:47 am
See the rods inside the shifter hole? They have little notches in them, you need to stick a screwdriver in there and move them around into the right spot, then just slot the shifter in!
Post Posted: Mon Jul 05, 2010 1:52 am
righto thanks for that i will have a go at it later on today
Post Posted: Mon Jul 05, 2010 8:08 am
all sorted out it was just the gates had moved so we put a screwdriver down it and they clicked into position
Thanks for your help trent
Users browsing this forum: No registered users and 405 guests
