| transfer case stuck in 4h https://auszookers.com/forum/viewtopic.php?f=5&t=13289 |
| Author: | Trent1 [ Mon Jul 05, 2010 12:19 am ] |
| Post subject: | transfer case stuck in 4h |
hey all just wandering if anyone knows how to get my sierras transfer case out of 4h as it got stuck after pulling the lever out and putting it back in it wont move and the selector bush is fine any advise will be great thanks trent does a 1990 selector shifter for the transfer case fit into a 1994 transfer case |
| Author: | Ben_Sierra [ Mon Jul 05, 2010 12:28 am ] |
| Post subject: | Re: transfer case stuck in 4h |
You can't just shove the level back in, you need to line up the gates properly, how did you put it back in? |
| Author: | Trent1 [ Mon Jul 05, 2010 12:30 am ] |
if the gates had moved how would i realine them |
| Author: | fordem [ Mon Jul 05, 2010 12:56 am ] |
With a large screwdriver. |
| Author: | Trent1 [ Mon Jul 05, 2010 1:05 am ] |
thanks fordem is this fairly easy |
| Author: | Ben_Sierra [ Mon Jul 05, 2010 1:47 am ] |
See the rods inside the shifter hole? They have little notches in them, you need to stick a screwdriver in there and move them around into the right spot, then just slot the shifter in! |
| Author: | Trent1 [ Mon Jul 05, 2010 1:52 am ] |
righto thanks for that i will have a go at it later on today |
| Author: | Trent1 [ Mon Jul 05, 2010 8:08 am ] |
all sorted out it was just the gates had moved so we put a screwdriver down it and they clicked into position Thanks for your help trent |
