It is currently Thu Oct 29, 2026 4:11 pm
Post Posted: Mon Jul 05, 2010 12:22 pm
Ok recently me and superduki rebuilt my gearbox, long and the short of is is..
we are using the coily gearset in a NT housing.. my housing was trashed.
issues are..
the gearbox is nearly locked up.. its turnable but only just.. MASIVE strain on motor in nutral (drops about 500rpm at idel when u pull the clutch out)
and the shifter rails, all of them are... well basicly seased.. we have got them to move a little bit with bruit force but yeah...
any ideas guys?
Post Posted: Mon Jul 05, 2010 12:30 pm
Coil sierras had slightly different ratios for at least some gears. Did you measure both gearsets to ensure they were exactly the same size?
Post Posted: Mon Jul 05, 2010 12:35 pm
2 be honest no.
they appeard to be completley identical and went together very smoothly...
we were thinking maby the box was a tad tight due to new bearings etc.. but this is stupid!
Post Posted: Mon Jul 05, 2010 1:06 pm
jonno_racing wrote:
2 be honest no.
Went together very smoothly?? Do u rotate the input shaft and check gear selection before you put it in your car? Pull it out again and check if all teh bearings are full seated. I had a tight box because of this.
Post Posted: Mon Jul 05, 2010 1:08 pm
yeah we did! it all appeared fine... it was just tight...
we however didn't think to check gear selection..
i will pull it out this week and chuck another one in for the time being.
Post Posted: Mon Jul 05, 2010 1:17 pm
Tight!! IF the engine drops by 500rpm as you said it would be freaking tight. Musta had a good grip on that input shaft to turn it over. What gear was it in when it appeared fine?
Post Posted: Mon Jul 05, 2010 1:30 pm
nutral.
yeah.. its very tight..
we cant get it in2 gear..
i think we might get a nt housing and swap internals.. the issue is there i thnk.
Users browsing this forum: No registered users and 288 guests
