| wiring a g16b into sierra need a bit of help. https://auszookers.com/forum/viewtopic.php?f=5&t=13342 |
| Author: | matty87 [ Tue Jul 06, 2010 11:47 am ] |
| Post subject: | wiring a g16b into sierra need a bit of help. |
ok fellas iv put the g16b out of a 2000 baleno into the sierra and most of the wiring is sweet. just a few questions about the 3 conections that come off the sierra gear box what are each one for? one is obviously for reverse sensor what are the others for? |
| Author: | Fatzook [ Tue Jul 06, 2010 1:03 pm ] |
| Post subject: | Re: wiring a g16b into sierra need a bit of help. |
emmissions I think. None of mine are connected at all ( with G16B also) and I've got no issues at all. |
| Author: | matty87 [ Tue Jul 06, 2010 1:27 pm ] |
Fatzook wrote: emmissions I think. None of mine are connected at all ( with G16B also) and I've got no issues at all.
so the two conections in the g16b wiring loom that were connected to the baleno gearbox dont need to be connected to anything on the sierra either? |
| Author: | Fatzook [ Tue Jul 06, 2010 1:32 pm ] |
matty87 wrote: Fatzook wrote: emmissions I think. None of mine are connected at all ( with G16B also) and I've got no issues at all. so the two conections in the g16b wiring loom that were connected to the baleno gearbox dont need to be connected to anything on the sierra either? I cut those complete out of the loom. Bluesuzy has a baleno motor in his aswell. Maybe shoot him a PM and see what he did.? |
| Author: | losfer [ Wed Jul 07, 2010 9:39 am ] |
the only things that plug onto a baleno gearbox are the reverse switch and the socket for the speedo/vss , so if anything the vss would be the only thing you would be concerned about. i have done a late model baleno install into a sierra before and never used the vss and didnt have a problem . |
| Author: | matty87 [ Wed Jul 07, 2010 1:21 pm ] |
sweet thanks fellas. also iv got the wires that went to the ignition barrel i know which ones are for the starter circuit but what are the colours of the acc 1 and 2 circuit wires if that makes sense as im going to just wire them up to 2 switches and a start button. |
| Author: | Fatzook [ Wed Jul 07, 2010 1:59 pm ] |
matty87 wrote: sweet thanks fellas.
also iv got the wires that went to the ignition barrel i know which ones are for the starter circuit but what are the colours of the acc 1 and 2 circuit wires if that makes sense as im going to just wire them up to 2 switches and a start button. Is this a race car? |
| Author: | matty87 [ Thu Jul 08, 2010 12:12 am ] |
Fatzook wrote: matty87 wrote: sweet thanks fellas. also iv got the wires that went to the ignition barrel i know which ones are for the starter circuit but what are the colours of the acc 1 and 2 circuit wires if that makes sense as im going to just wire them up to 2 switches and a start button. Is this a race car? yep it is a race car. |
| Author: | Fatzook [ Thu Jul 08, 2010 1:10 am ] |
matty87 wrote: Fatzook wrote: matty87 wrote: sweet thanks fellas. also iv got the wires that went to the ignition barrel i know which ones are for the starter circuit but what are the colours of the acc 1 and 2 circuit wires if that makes sense as im going to just wire them up to 2 switches and a start button. Is this a race car? yep it is a race car.
| Author: | BlueSuzy [ Thu Jul 08, 2010 3:15 am ] |
LOL. I only have bal gearbox vss to vitara speedo unit running from sierra cable. |
