It is currently Sun Oct 18, 2026 5:38 pm
Post Posted: Mon Sep 17, 2007 8:52 pm
I know this has been done to death but I'm just clearing up a few things in my head.
What's the max suspsension lift for a GV without going down the Calmini path? I have an OME lift (35mm) atm and am looking at putting in coil spacers. I was thinking about getting an additional 20mm lift, which translates to 10mm spacers for the front and 20mm for the rear.
Is it possible to go higher then a 55mm lift concidering the potential for CV damage?
Does coil spacers make the suspension worse (perform worse?) or is it not just as good as longer coils?
Will I need camber adjustments bolts as well? I think Pedders does these and people have seen good results? Does someone know how much these cost?
The reason for this lift is so I can better departure angles since I'm always banging my H/R towbar and my OE fuel tank protection plate.
2002 SWB GV
Lifted and Locked
Post Posted: Wed Sep 19, 2007 6:26 pm
You need to talk to Bruce. He has a 2000 GV with Rancho rears & OME fronts it has nice flex.. :mrgreen:
I'm fairly sure you could go 50mm lift without fear of damaging your CV's as long as you dont go bouncing the thing and shocking them to death.
I installed a 70mm lift into my mates 98 Vitara King Coils & Spacers (Has same front end as a GV) and he has no worries. His CV's are on a better angle than mine due to the different lower control arms. & I've dropped my Diff 2" 8O have a look and see what you rekon.
You will need camber pins and they are not cheap.. I got mine from Pedders and they were $110.
See it here -->http://www.nbs4x4club.com/forum/index.php?topic=7444.0
Thanks,
Chris
