It is currently Sun Oct 18, 2026 5:38 pm
Post new topic Reply to topic  [ 29 posts ]
Post Posted: Wed Sep 19, 2007 12:42 am
How much extra flex would i get with drop shackles>wat sizes are they
how much are they new?
[img]http://www.nbs4x4club.com/forum/files/thumbs/
Post Posted: Wed Sep 19, 2007 1:06 am
length of drop shackles open-minus length of shackles you are taking off/2
bugger all really, only benefit is maybe more sideways movement (good for flex, bad for stability)
Post Posted: Wed Sep 19, 2007 1:11 am
yeh, sum1 has some brand new ones for 200. seperior bbs. thinking about getting them.
Post Posted: Thu Sep 20, 2007 12:23 am
the way i see it... and i just got a pair from steve, and i'll see once I've installed them, but the whole idea of them is more downward travel.. therefore keeping the wheel's on the ground... more drive..!
Post Posted: Thu Sep 20, 2007 12:40 am
yeh i know, but i wasn't sure if they usually fully open or not to give max flex.
i need to see if my shocks are going to be long enough first
Vehicle: 75 Cruiser
Post Posted: Thu Sep 20, 2007 10:43 pm
just chuck em on, break your shocks and get new ones later.
i think they could be good if you can play around with springs and shocks to get them to work properly. all the zoh dudes have them front and rear and they seem to work well. They have all done some kind of custom spring pack also.
Post Posted: Thu Sep 20, 2007 11:52 pm
cool
Vehicle: 75 Cruiser
Post Posted: Thu Sep 20, 2007 11:58 pm
well, that sounds reckless doesnt it, heh, i never broke my shocks.
I think a good design track bar would help also, so you don't get too much diff twist/spring wrap.
Post Posted: Fri Sep 21, 2007 12:02 am
iam allready getting pretty big spring twist i thought the drops would help,
my back shocks are tarago one or something which have more travel then the bombodore ones i thing. u think they will not be too short.
can i more the rear brake bracket to get the liine closer to diff so i dont have to but another extended line?
us zook owners tend to be wreckless dont we
Vehicle: 75 Cruiser
Post Posted: Fri Sep 21, 2007 12:08 am
i don't think the shackles will help with spring wrap. if anything , they will let the diff flex more because it's allowed to move more freely.
if you stick the drop shackles on and take the shocks off at the bottom, and flex it up, then see if the shocks will reach still.
Post Posted: Fri Sep 21, 2007 12:10 am
ok cool. cheers big ears
Post Posted: Fri Sep 21, 2007 12:20 am
I just twisted the bracket on the chassis end so it pointed at the diff more and that took a lot of strain off it
Post Posted: Fri Sep 21, 2007 12:59 am
cool, i was thinking that, but wasn't sure if it would be enough.
i guess i need to just put them on and flex it up and do all these things
Post Posted: Mon Oct 01, 2007 1:50 am
Did i put these in right??????
Post Posted: Mon Oct 01, 2007 2:00 am
ive seen them fitted the other way
Post Posted: Mon Oct 01, 2007 2:04 am
damn
Post Posted: Mon Oct 01, 2007 12:25 pm
nope they will fight like buggery and twist the spring on bumps like that
Post Posted: Mon Oct 01, 2007 1:22 pm
so i wanna reverse then so they are bent foward? or are they upside down as well?
I think iam meant to have them facing foward, but i have tags welded on in front of puchases to stop shackles friping around. and on the drivers sided it would take out the fuel filler
What do i do here? cut off tags and?
Post Posted: Mon Oct 01, 2007 6:08 pm
Post Posted: Mon Oct 01, 2007 6:52 pm
I think like pic 2 but upside down
Post Posted: Mon Oct 01, 2007 7:03 pm
so like this. i leave the tag?
Post Posted: Mon Oct 01, 2007 7:15 pm
yeah I think thats it
piss the tag off, does nothing
see, you shoulda jsut got longer springs :wink:
Post Posted: Mon Oct 01, 2007 7:30 pm
hahaha,yeh
cheers
it flexed up pretty good last night with it on the wrong way
Post Posted: Tue Oct 02, 2007 1:40 am
I guess the ones you can see on the Superior website gallery would the correct way. http://www.superiorengineering.com.au/g ... ure&id=289
Post Posted: Tue Oct 02, 2007 1:58 am
yeh i seen that then confirmed it with the previous owner
cheers
Post Posted: Wed Oct 10, 2007 2:09 am
how are these goin have the made any diff?
Post Posted: Wed Oct 10, 2007 3:34 am
The sticker would give it away, Mick would put the sticker up the other way if they were meant to be that way.
Post Posted: Thu Oct 11, 2007 12:09 am
havent tested them yet ah, been too busy, will try and get out this week and get some pics.
