It is currently Tue Oct 27, 2026 2:42 pm
Vehicle: LPG 1.6 Sierra
Post Posted: Sat Jul 10, 2010 11:47 pm
My zook must have had a hell of a life at the hands of the previous owner, it's been job after job just to get it looking like a tidy stocker again.
One of the last jobs before I start priming up panels is to fix the gaps around the flare guards - not one flare on my car is a snug fit with the wheel arch, they've all got 1 - 2mm gaps somewhere along the welting.
I think it'd be silly to respray and not fix these gaps up, but not sure if i'm biting off more than I can chew. I'm yet to pull the guards off and see how they attach to the wheel arch... maybe I can do that later this arvo.
Rather than new welting can I caulk up these gaps?
Also - i've been told left front / right rear guards are the same, so too right front / left rear. Has anyone ever put them on the wrong guard? Just wondering if that's what's causing this gap, as there's no obvious panel damage causing it
Post Posted: Sat Jul 10, 2010 11:52 pm
don't worry about it, it's a sierra, and every sierra has gaps from factory.... most come with optional panel gaps, they call it rust...
Vehicle: jimny
Post Posted: Sun Jul 11, 2010 12:22 am
You could try lossening the bolts and pushing the flare then re tensioning it. If your painting green you won want those flare rubbers anyway as they are white rubber
Post Posted: Sun Jul 11, 2010 12:44 am
I'm thinking of using sikaflex instead of the flare rubbers / welting - this'd do the job, wouldn't it?
Vehicle: Nissan
Post Posted: Sun Jul 11, 2010 12:46 am
Buy these problem solved
http://www.doubleblackoffroad.com/main.php
have a look half way down
http://www.auszookers.com/index.php?nam ... &start=210
Pearce-toff Racing
Post Posted: Sun Jul 11, 2010 12:50 am
Sweet - but just a little more $$$ than I got to spend (damn, they'd be perfect though). How long did it take to put them on?
Nice build up BTW Alex, looks like a fun project
Vehicle: Nissan
Post Posted: Sun Jul 11, 2010 1:01 am
about an hour arfter the flairs are off :)
thanks mate 8) :D
Pearce-toff Racing
Post Posted: Sun Jul 11, 2010 1:30 am
you really want to paint the car with the frares off the vehicle as the paint will bridge other wise and flake around there later.
the other reason is that you get to clean under the flare and reseal and color that area with new paint.
the wadding/fill strip is not supposed to be painted as its the flexable component of the joint it will always crack and peal eventually if painted.
I would not sika the flare gaps as it will cause you other problems later if you bash or want to remove the flare.
Users browsing this forum: No registered users and 188 guests
