It is currently Thu Oct 29, 2026 7:29 pm
Vehicle: '92 Sierra
Post Posted: Mon Jul 12, 2010 12:06 am
Had my third apart. Now should I set the backlash to spec or should I set it to what it already was? It was .19mm whereas the max range in the workshop manual is .15mm. I was wondering if I reset it to within factory range will it be noisy due to it already being worn in at .19mm.
Post Posted: Mon Jul 12, 2010 6:52 am
Set it to that, .04 is not a lot, but still set it to spec's.
Pinion bearing's ok???
Vehicle: '92 Sierra
Post Posted: Tue Jul 13, 2010 12:25 am
No dramas with any of the bearings from the axles right through to the pinion suprisingly. I really did expect the axle bearings to be shagged. I didn't think .04 was a problem hence not knowing whether or not to take it back to spec. I've ordered a spring balance to check the preload on the pinion and side bearings.
Users browsing this forum: Google [Bot] and 116 guests
