| 1L to 1.3L engine mounts https://auszookers.com/forum/viewtopic.php?f=5&t=13514 |
| Author: | wharf [ Tue Jul 13, 2010 7:51 am ] |
| Post subject: | 1L to 1.3L engine mounts |
After having a good look at the mounts in both zooks i can see that the 1L mounts are further back towards the firewall and also sit on top of the rails.Where as the 1.3 looks like it sits between the rails more. Is there an after market kit for the mounts i can buy?or do i have to make it? Also will the extension shaft from the 5 speed fit onto the 1L transfer flange? I will take some pics to explain better after dinner. |
| Author: | rogerworkman [ Tue Jul 13, 2010 8:01 am ] |
| Post subject: | Re: 1L to 1.3L engine mounts |
when i put a 1.3 into my 1 litre sierra i just cut the 1.3 mounts out of another sierra , then bolted the mounts to the motor then when the motor was lined up i welded them in, as for the jack shaft u could just swap the flange on the transfer so u can use the 1.3 jack shaft |
| Author: | wharf [ Tue Jul 13, 2010 12:04 pm ] |
Thanks man.When i swap the flanges will they just bolt on?Will it need to be shimmed? |
| Author: | Crunched [ Tue Jul 13, 2010 9:40 pm ] |
rogerworkman wrote: when i put a 1.3 into my 1 litre sierra i just cut the 1.3 mounts out of another sierra , then bolted the mounts to the motor then when the motor was lined up i welded them in...
Ditto. |
| Author: | 2stroker [ Tue Jul 13, 2010 11:00 pm ] |
rogerworkman wrote: when i put a 1.3 into my 1 litre sierra i just cut the 1.3 mounts out of another sierra , then bolted the mounts to the motor then when the motor was lined up i welded them in, as for the jack shaft u could just swap the flange on the transfer so u can use the 1.3 jack shaft
I agree this is the best way to go, be aware that there are two different length jackshafts available for 1 litre sierra's depending on the year, early ones had a longer shaft. |
| Author: | wharf [ Wed Jul 14, 2010 8:31 am ] |
Its an 84 model.I will measure the both of them when i get the 1.3 out.Thanks |
