https://auszookers.com/forum/
HELP. I fuked up.. again. Rear door lock on GV
https://auszookers.com/forum/viewtopic.php?f=5&t=13726
Author:  TheOtherLeft [ Thu Jul 22, 2010 2:56 am ]
Post subject:  HELP. I fuked up.. again. Rear door lock on GV
I've somehow screwed up the back door lock. I've somehow pushed the tongue backwards on the latch and now it won't rotate back to its normal position and hence won't engage as per normal, ie I can't close the rear door.
I've tried the key in the rear & drivers door, central locking. Nothing.
Is there a way to free up the tongue/latch?
Author:  atari4x4 [ Thu Jul 22, 2010 2:57 am ]
Post subject:  Re: HELP. I fuked up.. again. Rear door lock on GV
you should be able to flick it back with a screw driver
Author:  TheOtherLeft [ Thu Jul 22, 2010 2:59 am ]
tried that... didn't work. It's like it's somehow now engaged
Author:  atari4x4 [ Thu Jul 22, 2010 3:04 am ]
tried lifting the handle.... i just went & did the same thing to mine, pushing the latch mecho right in & lifting the handle flicks it back.
unless it's a coily/GV thing, if so.... may i suggest selling it.
Author:  atari4x4 [ Thu Jul 22, 2010 3:09 am ]
is the child lock engaged?
Author:  TheOtherLeft [ Thu Jul 22, 2010 3:20 am ]
It's a shorty GV. Is there a child lock?
Author:  atari4x4 [ Thu Jul 22, 2010 3:32 am ]
i don't know... it's your car?
Author:  tanshi [ Thu Jul 22, 2010 3:32 am ]
get some one to hold the handle up like your opening the door (make sure its not locked.)
slip a screw driver into the hole, and tapp it sideways with a hammer
Author:  TheOtherLeft [ Thu Jul 22, 2010 3:34 am ]
Hellefukingluyah!!! Atari I'm going to give you the biggest blowie of your life.
The handle trick didn't quite work as the plastic tongue behind the handle flexed a little too much, so I engaged it from inside of the door (the horizontal silvery rod thing in the pic) instead.
Author:  atari4x4 [ Thu Jul 22, 2010 3:34 am ]
thanks but NO THANKS....
Author:  stockman [ Thu Jul 22, 2010 3:39 am ]
8O 8O 8O 8O 8O 8O 8O
Author:  MacDaddy [ Thu Jul 22, 2010 5:51 am ]
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
Author:  Suzi.zook [ Thu Jul 22, 2010 6:24 am ]
