| Author |
Message |
ianscott2003
Joined: Wed Jul 21, 2010 9:48 pm Posts: 23 Location: Yeppoon QLD
 Posted: Fri Jul 23, 2010 4:37 am |
I have just rang my local repco and suzuki dealer and both want around $350 just for the fuel filter. Does anyone know where to get one any cheaper?
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Fri Jul 23, 2010 4:48 am |
You could try Suzi Auto Services or Suzisport and see what they quote.
They aren't a cheap filter like Sierras though - the jimny ones are mounted inside the tank.
gman
Joined: Tue Dec 01, 2009 10:30 pm Posts: 172 Location: Longford, Tasmania
 Posted: Fri Jul 23, 2010 4:50 am |
how many k's does has ya jimny have on it? they arn't cheap but than again if you only have to change them every 230000km's.
ianscott2003
 Posted: Fri Jul 23, 2010 4:57 am |
ha ha yeah almost exactly 230000kms it is getting a shudder every now and again probably once a week I suppose. But goes quickly just doesn's seem to be getting enough fuel.
ianscott2003
 Posted: Fri Jul 23, 2010 5:07 am |
Just talked to Suzisport he thinks it isnt the fuel filter and that it is more likely an engine sensor. I have heard of crank angle sensors causing similar issues.
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Fri Jul 23, 2010 5:18 am |
i have also heard of g13bbs having an issue like this. they have a cam shaft sensor, they dont have a crank sensor i dont think
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13014 Location: Melbourne
 Posted: Fri Jul 23, 2010 7:23 am |
99% it will be the camshaft angle sensor. 230000km is a good run from one - many fail well before 100000km. A random shudder is one symptom. Stalling at idle when hot is another.
A blocked fuel filter will give a lean out condition under full power due to falling fuel pressure, and will be present under all identical conditions. Give the car a long, full throttle pull in, say, 3rd gear - if it doesn't start to feel choked or restricted it's unlikely to be fuel filter related.
dm90
Joined: Sun Nov 29, 2009 10:30 pm Posts: 4349 Location: Perth
 Posted: Fri Jul 23, 2010 10:14 am |
unfortunately thats how much they are, and expensive to fit, as stated before they are inside the tank so it needs to come off first.
ianscott2003
 Posted: Fri Jul 23, 2010 10:38 am |
How much is a cam shaft angle sensor
losfer
 Posted: Fri Jul 23, 2010 10:49 am |
squizzytaylor
Joined: Sat Sep 26, 2009 11:30 pm Posts: 381 Location: Bogged near Morisset
 Posted: Fri Jul 23, 2010 10:58 am |
gman
 Posted: Fri Jul 23, 2010 9:39 pm |
