It is currently Fri Oct 30, 2026 11:36 pm
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Jul 23, 2010 7:38 am
My car is now 80% primed up and i want to sort out a few scratches and light dings that the primer can't fill.
What's the rule with putty and bog - can I use it over the top of primer or does it 'have' to go onto bare metal? i'll prime back over the top of any filled up areas... info is a little vague so if anyone can clarify i'll be grateful
Post Posted: Fri Jul 23, 2010 7:56 am
spray putty can go over primer or u could use stop putty its in a tube , its good for little nicks or scraches
Post Posted: Fri Jul 23, 2010 8:37 am
Bog is fine to go on primer
Vehicle: 03 Jimny
Post Posted: Fri Jul 23, 2010 8:55 am
i usually sand the area back to bare metal, as i think it will have a better chance of sticking. but put it on primer and see how it goes
Post Posted: Fri Jul 23, 2010 9:32 am
depending on the type of primer
acrylic primer use stop putty
two pak primer you can use bog although its not a very good way of doing it as it tends to have air bubbles and other inpurities , the best way is to use a poyester fine fill.
be carefull on all acrylics as they shrink and you may see scratches later
also be careful of getting bog wet as it can cause humity blisters later.
Post Posted: Fri Jul 23, 2010 9:37 am
bog is always SUPPOSED to be used over bear metal after being ground off or a least heavily sanded.
the grinding/sanding keys it to the panel.bog is a poyester fiberglass resin base with a soft filling agent sort of like polystyene. thats why it sticks well but is easy to sand.
Post Posted: Fri Jul 23, 2010 10:55 am
ajsr wrote:
be careful of getting bog wet as it can cause humity blisters later. 8O
Don't feed me after midnight either! :twisted: :lol:
Bitumen...Another waste of public funds!
Post Posted: Fri Jul 23, 2010 11:27 am
we need photos of ajsr getting bogged wet.
Actually NO WE DONT. 8O
Post Posted: Fri Jul 23, 2010 11:35 am
You were the last one here to get me wet remember? CARWASH :lol:
Post Posted: Fri Jul 23, 2010 1:40 pm
Can I get stop putty from repco/supercheap? I saw spray putty in a can at repco, but didn't have an eye out for the stop putty stuff.
Also - on a similar subject - what sort of Sikaflex to use... there's about 10 different options at Bunnings... surely there's is a 'best' option. Main purpose is to bury the seams in the gutter rails as it was beforeI attacked it with a wire wheel (I stripped the original caulking out so I could vice clamp the gutters straight... worked a treat).
Post Posted: Fri Jul 23, 2010 9:03 pm
just for you jason and rob :thefinger: :wink:
there is several auto grades of sika
but Im a big fan of the general auto and glass(dont remember the number) just get on that has a pic of a car on it and you will be fine
Post Posted: Sun Jul 25, 2010 8:30 am
I have always put bog on primer.
Never on bare metal as it doesnt stick proper.
Never had a problem (even after 10 years + of driving)
Bog on bare metal will look good but tends to peel off.
Post Posted: Sun Jul 25, 2010 8:34 am
Realy??? :?
Post Posted: Sun Jul 25, 2010 8:42 am
yes
we have repaired many panel jobs from people that had (had a go)
most of them are
A) bare metal
B) to much bog
C) overall stuffed job:P
some basic tips for body work would be
use as little bog as possible.
allow for the bog and or primer to (sink back) before standing.
Post Posted: Sun Jul 25, 2010 9:05 am
So taring over the top of dirt's fine then?? :P :roll:
I was taught year's ago that it was best to apply to bare metal.
Post Posted: Sun Jul 25, 2010 9:07 am
and yet you are total WRONG
if you read my post again (yes I know it may seem complicated)
body filler (bog) is supposed to go directly onto clean keyed metal.
keyed means ground or heavily sanded.
now you can tell eveyone to do the wrong thing like you have, or you can learn something.
the only filling products that are supposed to go over paint/primers are-
polyeseter fine fill (2 pak)
stop putty (acrylic)
if you still cant fathom this get a can and try reading the back.They put all kinds of fun stuff on the back of cans.
Post Posted: Sun Jul 25, 2010 9:12 am
meh just giving my two cents.
I lernt from both my father and a family friend.
our friends family have been panel beaters for over 3 generations.
I have seen the effects of both first hand first hand.
Post Posted: Sun Jul 25, 2010 9:14 am
http://www.hichem.info/
Post Posted: Sun Jul 25, 2010 9:17 am
so both your father and friend know fuck all about the basics of fixing cars.
please stop making yourself look stupid , I was a tech rep for wattyl paints for a few years after I sold my panelshop.
i have always used bog on bare metal
I Use a product called metal plastic which is more of a putty filler and this generally adheres very well to primed surfaces.
Most bog and puttys need a polyester putty/filler sprayed over them and then priming after a light sand, to reduce the sinckback effect common when
priming straight over bog.
Post Posted: Sun Jul 25, 2010 9:45 am
Not here for a shit fight just saying what has worked for me and others I know
But hey do what ever you thinks best
Post Posted: Sun Jul 25, 2010 8:34 pm
Forget it AJ, some people will never admit when they are wrong. :roll:
Anyone with any experience knows the only thing that sticks to primer is paint.
Post Posted: Mon Jul 26, 2010 2:15 am
:goodjob: good for you buddy but i know what ill be continuing to do
Post Posted: Sat Aug 07, 2010 2:42 pm
Will bog melt if it's too hot? My exhaust tip is about 3 inches away from a bit I want to bog on the lower back corner. I'm using the 3M lightweight auto filler bought from Repco, it says nothing on the jar but I think it's a poly-something filler - plastic. Not sure what heat resistance this stuff has.
Post Posted: Sat Aug 07, 2010 11:34 pm
it will be fine mate.
good choice in filler too
Vehicle: LJ20 LJ50
Post Posted: Sun Aug 08, 2010 12:28 am
Why do all car manufacturers use it under the primer on bare metal on brand new cars?????????
Vehicle: jimny
Post Posted: Sun Aug 08, 2010 4:44 am
hmm, dodgy panel beaters that do dodgy car yard work are the only idiots that put bog on top of any paint, bog is best applied to a clean bare metal surface, laziness can lead to it going on paint also. i reckon we need some pics of all your hard work che_guitarra
Post Posted: Sun Aug 08, 2010 6:17 am
you know the more I think about it, this is probably DAK DAK DAVE in disguise. He is the only farktard I know that will still argure a proven wrong point till hell freezes over . :wink: and still belive he is right.
yeah pics are needed che
Post Posted: Sun Aug 08, 2010 6:48 am
Quick question ajsr, how many years have you been working in the panel beating industry?
Probably a few more than skelaaleks... But then some people always think they're right...
Che, I know who's advice I'd be following, and who's I'd be ignoring...
Bog goes on bare metal. I'm certainly no panel beater but even I know that one (from reading the instructions on the tin :roll: )
I want my old sig back :(
Post Posted: Sun Aug 08, 2010 7:45 am
hey ben
Im not in the panel trade these days. But I spent 17 years in the trade, 4 of which were managing sections of others shops and 5 years running my own shop
I then spent 18 mths as a technical demonstrator for wattyl paints.
I gave up the trade when my father got cancer ,to help run his company.
these days I have a construction company that builds large commercial green houses and hail netting structures over orchards.
cheers andrew
Users browsing this forum: No registered users and 401 guests
