| Author |
Message |
sleeperzook
Joined: Mon Jul 06, 2009 11:30 pm Posts: 208 Location: Adelaide
 Posted: Sat Jul 24, 2010 8:59 am |
Ok guys, so Ive searched here and outers and haven't got the answer I'm looking for.
I've got an mx82 cressida p/s box and can get the pump for next to nothing. I'm just wondering why some people and places like rocky road say to use the mx 32/62 boxes. How are they different to my mx82 box and could I make mine work? I will pull the pitman arm off to see if the taper suits my sierra, if not what do people recommend for a zook with 2" BL, 2" springs, just running 235's?
My second question is about the pump. Can anyone tell me what the pressure/flow requirements for a box are relative to a rack? Ie could any pump hack it, or should I source one off a p/s box vehicle? This leads to the last of my questions. I'm running a turbo GTi donk, and the pump will have to go on the passengers side near the exhaust. Should I be using a pump, such as the VS commodore that has remote reservoir and a massive multi rib pulley, to hopefully keep the rpm of the pump to a reasonable level? (my rev limit is set to 7800).
Aaron
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sat Jul 24, 2010 9:37 am |
Don't know about Mazda boxes but I run a genuine Sierra powersteer box with a Celica rack pump... Works fine.
atari4x4
 Posted: Sat Jul 24, 2010 9:54 am |
i'm pretty sure, they are toyota PS box numbers not mazda.
sleeperzook
 Posted: Sat Jul 24, 2010 11:13 am |
Yeah I've got the box and pump from an 82 cressida. Also looking at an early model mitsubishi triton pump, as its small, has a remote reservoir and was designed for a 4WD with 235's like mine  Just wondering if anyone has any ideas to add, I'd rather hear them now, than 'you should have done........'  Cheers
BlueSuzy
 Posted: Sat Jul 24, 2010 11:40 am |
Alot of people run a falcon teardrop shape ps pump. Come in both mulit v and single vee.
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Sat Jul 24, 2010 11:50 am |
BlueSuzy wrote: Alot of people run a falcon teardrop shape ps pump. Come in both mulit v and single vee.
sleeperzook
 Posted: Sat Jul 24, 2010 11:57 am |
Yeah Ive read that a fair bit. My issue is because I have a turbo set up I have to fit the pump between a manifold on tope, a sandwich plate behind and oil lines/intercooler pipes that run up the passenger side. Hence why I'm leaning towards a remote reservoir. My main question really is why people specify the 78-81 cressida boxes? My 82 appears to be the same box. Are they a different spline, bolt pattern or gearing etc?
Cheers for the help
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sat Jul 24, 2010 7:34 pm |
Try this. you might need to run a cooler and a bigger resiviour, but it should be up to the task
BenT
Joined: Sun Nov 16, 2008 10:30 pm Posts: 208 Location: Nelson, NZ
Vehicle: 85 SJ413
 Posted: Sat Jul 24, 2010 10:24 pm |
If your box is from an 82 then it should be an MX62 Cressida. The 62 refers to the model not the year. Later models had rack and pinion steering.
For the pitman arm, the Sierra one won't fit, but a Vitara pitman arm will. The Vit arm is flat though, so you might end up with a little bump steer with 2" lift. You could use a drop pitman for a Vitara.
I use a Vitara pump to drive my Celica box and it works great.
I make bolt on adaptor plates to mount these boxes to the chassis if you want one. I also do a plate to mount a Vitara pump to a 1300 or 1600 in a Sierra.
Ben
_________________ WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
31zook
 Posted: Sun Jul 25, 2010 8:13 am |
I've heard that alot of toyota pitman arms fit also....
slyvan1
Joined: Mon Sep 29, 2008 11:30 pm Posts: 66 Location: emerald
 Posted: Wed Jul 28, 2010 10:44 am |
does the toyota box take up any more room than the original sierra box, my radiator sits really close to the box.
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Wed Jul 28, 2010 11:44 am |
slyvan1 wrote: does the toyota box take up any more room than the original sierra box, my radiator sits really close to the box.
All P/s box's are bigger than a sierra box, jimny is the closest I've seen to the same size
_________________ I used to be indecisive,
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Wed Jul 28, 2010 11:47 am |
steknig wrote: slyvan1 wrote: does the toyota box take up any more room than the original sierra box, my radiator sits really close to the box. All P/s box's are bigger than a sierra box, jimny is the closest I've seen to the same size
Yeah my jimny P/S box is only slightly bigger than my sierra steer box. But my vitara P/S box is heaps bigger.
_________________ 2013 GV 1998 SV420 ute
royce
 Posted: Wed Jul 28, 2010 11:50 am |
you get a different radiator bracket on sierras with power steer to clear it
and vit rad and sierra / jimny power steer will squeeze into a sierra, but they rub pretty hard
Fatzook
 Posted: Wed Jul 28, 2010 11:53 am |
royce wrote: and vit rad and sierra / jimny power steer will squeeze into a sierra, but they rub pretty hard
Yes they do require a little MANipulation to fit
BenT
Vehicle: 85 SJ413
 Posted: Thu Jul 29, 2010 5:32 am |
The Toyota box will fit with the stock radiator in the stock position.
Ben
slyvan1
 Posted: Mon Aug 30, 2010 8:23 am |
fitted power steering using cressida box and falcon pump. The diagram joe blow posted on outers was a little different to my chassis. I think this is because i have a 1litre lwb chassis. Just meant none of the original holes lined up. So i just put it as far forward as i could mount it. This is a really good conversion and works really well.
At the weekend i did a high country trip, and i blew the high pressure line of its fitting. I used lpg flex line and the screw in fittings. it looks very similar to red89 picture. the line blew where it screws into the fitting. The hose felt very soft and swallon, normally its really stiff.
Was wondering if this line is no good? Or if i need to fit a cooler? The lines get really hot. The return is 8mm trans hose about 1.5 metre long, high pressure is the same length.
rick1970
Joined: Sun Jul 04, 2010 9:39 pm Posts: 303 Location: Dungowan
 Posted: Mon Aug 30, 2010 6:30 pm |
LP gas hose is most definatly not the stuff to use.
If it looks the same as the pic and has a woven outer covering (automotive LPG hose) , you can use your existing fitting on the proper hose. Go to your local hydraulic shop and get SAE100R5 hose, Aeroquip FC350-6, Gates 6C5C etc.........most will have an equivilant.
Would have thought 5/16" (8mm) would be a bit small for the return side, most use 3/8" (10mm). What size are the barbs on the box/resivoir?
