| 215 75 15 on 7inch rims https://auszookers.com/forum/viewtopic.php?f=5&t=13804 |
| Author: | BJPK [ Sun Jul 25, 2010 1:13 am ] |
| Post subject: | 215 75 15 on 7inch rims |
hey peeps running 215 75 15 mts on stock rims. but want to go to a 7inch rim as i have a set. but am worried bout rolling tyres off bead at low pressure. who here runs this combo? any probs? also not interested in going any bigger in tyres, as they are near new. cheers |
| Author: | Ben_Sierra [ Sun Jul 25, 2010 1:35 am ] |
| Post subject: | Re: 215 75 15 on 7inch rims |
Why do you want to go to 7 inch rims? 215s will be too narrow for 7 inch rims. The only reason for wanting to go to wider rims should be that you want to fit wider tyres... It doesn't make any sense to go to 7 inch with 215s.... |
| Author: | Joe [ Sun Jul 25, 2010 1:43 am ] |
BJPK wrote: hey peeps running 215 75 15 mts on stock rims.
but want to go to a 7inch rim as i have a set. but am worried bout rolling tyres off bead at low pressure. who here runs this combo? any probs? also not interested in going any bigger in tyres, as they are near new. cheers They will be fine mate, i had 215s with 7 inch rims on bullant years ago and never rolled a bead Are ya gunna use them alloys you were selling awhile ago they would look |
| Author: | BJPK [ Sun Jul 25, 2010 2:52 am ] |
Ben_Sierra wrote: Why do you want to go to 7 inch rims?
215s will be too narrow for 7 inch rims. The only reason for wanting to go to wider rims should be that you want to fit wider tyres... It doesn't make any sense to go to 7 inch with 215s.... yea man considering it. and Ben as joe said itl look |
| Author: | alien [ Sun Jul 25, 2010 3:29 am ] |
i'd go a 235/70r15 on a 7" rim... so 9.25" wide tyre instead of 8.4" - a 235/70 is also a 28" tyre, while your 215/75 is a 27"... so not a massive difference in height but a good difference in width - and most 15x7's have way more offset that standard rims (which have none). EDIT: the hankook's you're running now come in a 28x8.5r15 =) |
| Author: | royce [ Sun Jul 25, 2010 3:33 am ] |
it wont be a problem, remember tyres are held onto teh rim by pressurised air not the angle between the edge of the tread and the rim lip |
| Author: | Ben_Sierra [ Sun Jul 25, 2010 4:12 am ] |
royce wrote: it wont be a problem, remember tyres are held onto teh rim by pressurised air not the angle between the edge of the tread and the rim lip
This is true, but when you air down off road I know a lot of people find that if their rim is too wide for the tyre you end up with lots of mud in the beads and flat tyres... |
| Author: | BJPK [ Sun Jul 25, 2010 5:22 am ] |
alien wrote: i'd go a 235/70r15 on a 7" rim... so 9.25" wide tyre instead of 8.4" - a 235/70 is also a 28" tyre, while your 215/75 is a 27"... so not a massive difference in height but a good difference in width - and most 15x7's have way more offset that standard rims (which have none).
EDIT: the hankook's you're running now come in a 28x8.5r15 =) well im definatly not gettin new tyres, may jus swap em over at work and see. can always swap em back i guess. cheers guys. |
| Author: | Joe [ Sun Jul 25, 2010 7:22 am ] |
BJPK wrote: alien wrote: i'd go a 235/70r15 on a 7" rim... so 9.25" wide tyre instead of 8.4" - a 235/70 is also a 28" tyre, while your 215/75 is a 27"... so not a massive difference in height but a good difference in width - and most 15x7's have way more offset that standard rims (which have none). EDIT: the hankook's you're running now come in a 28x8.5r15 =) well im definatly not gettin new tyres, may jus swap em over at work and see. can always swap em back i guess. cheers guys. Pics of it when you do |
| Author: | alien [ Sun Jul 25, 2010 9:13 am ] |
yeah its prolly one of the cleanest sierras on here! |
| Author: | BJPK [ Sun Jul 25, 2010 10:54 am ] |
joseph wrote: BJPK wrote: alien wrote: i'd go a 235/70r15 on a 7" rim... so 9.25" wide tyre instead of 8.4" - a 235/70 is also a 28" tyre, while your 215/75 is a 27"... so not a massive difference in height but a good difference in width - and most 15x7's have way more offset that standard rims (which have none). EDIT: the hankook's you're running now come in a 28x8.5r15 =) well im definatly not gettin new tyres, may jus swap em over at work and see. can always swap em back i guess. cheers guys. Pics of it when you do one day il get around to it |
