It is currently Thu Oct 29, 2026 2:27 am
Post Posted: Sun Jul 25, 2010 8:56 am
my question is should diff breathers be made of a special hose ????
when i pulled my centre out i found water inside the housing as it had
a breather hose on it im asuming it must be getting hot enough to cause
condensation in the hose that trickles back into the housing. didnt see any
signs of water on the last change ????
Vehicle: jimny
Post Posted: Sun Jul 25, 2010 10:02 am
did your diff suck any water in on a water crossing through the axle seals?
Post Posted: Sun Jul 25, 2010 12:13 pm
i have read that the hose should be a fuel hose or similar as the diff fluid can destroy normal garden hose
Post Posted: Sun Jul 25, 2010 12:33 pm
eldo your onto something i think a bearing and seal was suspect on removal. didnt even think twice about it
Post Posted: Mon Jul 26, 2010 4:05 am
what about normal air line hose?
i use that, just keep it away from ya exaust ;)
Post Posted: Mon Jul 26, 2010 4:11 am
Normal rubber hoses are degraded by oil, so if used as a dff breather, where regularly exposed to oil, will degrade over time...
Some sort of oil resistant hose would be preferable, unless you want to keep changing hoses...
I want my old sig back :(
Post Posted: Mon Jul 26, 2010 4:13 am
same here. ball didn't even notice his hoses getting shorter. :lol:
Users browsing this forum: No registered users and 626 guests
