It is currently Fri Oct 30, 2026 12:49 am
Post Posted: Tue Jul 27, 2010 2:00 am
Looking through the service manual, I can't see anywhere how much auto transmission fluid it takes for a replacement. Any ideas?
Regards,
Ranga
Post Posted: Tue Jul 27, 2010 8:38 am
Just done mine and put abot 3 lt in.
Now remember that is in the BOX ONLY that is not a full oil change to do that you need a pump to enable you to pump it through the Tourque converter as well.
What i did was drained the oil then refilled it. Then Run the car for a few min and dropped the oil again and refilled it that way the car pumped it through.
Not the best way but unless you take it to a specialist that has the pump to do it about $ 170 for him to do oil filter and new pan gasket + check it all over. Might be worth it if you have issues with it.
Steve W
Post Posted: Tue Jul 27, 2010 8:55 am
3 speed is 5.1 ltrs for rebuild
Users browsing this forum: No registered users and 168 guests
