It is currently Wed Oct 28, 2026 4:24 pm
Post Posted: Wed Jul 28, 2010 6:52 am
I have a Sierra with 2in susp and bodylifts. Do i need a different pitman arm?, as the angle of the stock one just doesnt look right. Also, if i fit 2in shackles will it make it worse.
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Wed Jul 28, 2010 7:04 am
Maybe and yes.
Your body lift will not have effected the drag link angle. If you add extended shackles you may find you get a little more bump steer. Some 3 degree castor wedges, and a drop pitman arm will have it driving like stock again.
Pete
Post Posted: Thu Jul 29, 2010 3:21 am
Will this be affecting my steering, like make it harder to turn and always wanting to go straight. Or is that just the big tyres
Post Posted: Thu Jul 29, 2010 6:34 am
when did that start happening? when you put the tyres on? The lift will not cause that problem.
Post Posted: Thu Jul 29, 2010 8:14 am
No it steers the same with stock tyres. i mite be just used to power steering. Could it br the steering box as it seems to have a bit to much crap on it for my liking, although theres no noticable leak
Post Posted: Thu Jul 29, 2010 11:06 am
your box just isnt extremely worn n sloppy is it?
Post Posted: Fri Jul 30, 2010 12:50 am
I found when I extended my shackles this happened to me. Because the front diff had essentially been rolled forward, the front end geometry was up the creek. I found it would track straight, be hard to turn, to a point, then would pull towards full lock once you got about 2/3 of a turn in. As was mentioned, 3 degree castor blocks did the trick.
Users browsing this forum: No registered users and 312 guests
