It is currently Wed Oct 28, 2026 11:17 am
Vehicle: Suzuki Grand Vitara XL7 2004
Post Posted: Sun Jul 25, 2010 11:20 pm
g'day!
own a Suzuki X-90!
(aka Vitara)
1996, 1.6L 16valve, 42L fuel tank!
want to replace my fuel tank with something i guess bigger??
as if goes, a VL commodore shock fits the back end and give much flex..
i'm wanting to know is there similar circum stance where a i guess, Dihatsu feroza, (bigger tank) fit under my rig?
3" spring lift 3" body lift.. (plenty of space)
has any one heard of a tank that you can pull out and put in that will fit between the chassis rails???
Thanks if any one can give me any information!!!
Abs!!!
Post Posted: Sun Jul 25, 2010 11:26 pm
The only bigger tank that i have heard of is the longranger tanks for swb vitaras at $1200 a pop :roll:
You have the X90 from 4wd action ay?????You should post up some pics of it :P
Post Posted: Sun Jul 25, 2010 11:40 pm
2L vitara tank swb has 60L. they are very close to the 1.6, i think its the depth that makes the difference.
Post Posted: Sun Jul 25, 2010 11:47 pm
G'day!!
heh, my bro owns the 4wd action oscar, i own a second to standard X-90, mine has a 2" lift, designing custom bars and guard cuts going for 29" nankang mudstars in 3 weeks, then 2" extractors...
so there you have it, my bro however has asked me to find out if there is such a tank that will fit under it :)
Thanks for your advice!!!
Monster!!!
Post Posted: Sun Jul 25, 2010 11:51 pm
so they would fit but sit lower? is that what u mean by depth??
Post Posted: Mon Jul 26, 2010 12:01 am
depth is the same as heigth but just in the opposite direction :wink:
(yes i know heigth isn't a word but i think it should be, like width, length, depth.... stupid english language)
Bingo
i would still look between a 1.6 Lwb and 1.6 swb but i think they will fit, also the X90 in question has a 3 inch body lift so the tank could be lifted to fit on top of the chassie
Post Posted: Mon Jul 26, 2010 2:03 am
The 2L swb tanks are wider so they wouldn't fit between the chassis on a 1.6
Post Posted: Mon Jul 26, 2010 2:15 am
like i said check between the lwb and swb 1.6 models as the 2L tank looks very close to 1.6 wagon.
Post Posted: Mon Jul 26, 2010 2:19 am
I think the LWB tank would get stoved in by the diff on the SWB
Post Posted: Mon Jul 26, 2010 2:37 am
Negative Ghost rider!!
The 2L tank is also 50 mm wider, and won't fit between the chassis rails of an X-90 or SE model vitara. :cry:
The best you can hope for is the LWB SE416W tank (55L?), and that will be tight. It is the same depth, but wider in both directions. this may give you greif with your shocks.
Peter
Post Posted: Mon Jul 26, 2010 5:36 am
I just spat me coffee out lol, thanks mate.
Post Posted: Thu Jul 29, 2010 9:29 pm
hey guys!
after a bit of measurments, we have concluded
theat the lwb 1.6L wfi zook's tank is the closest fit with a 55L tank!
however, in the chassis there are them cylanders that run accross the width of the car, the problem is the depth? or rather the length accross the chassis as the tank does not fit between the two cylanders!
thus concluding that Oscar (the silver x-90) will probably be fited with a longranger tank or some such or have made a custom long range fuel tank!!!!
Absa!!!
Post Posted: Thu Jul 29, 2010 9:42 pm
Yeah the LWB 1.6 tank is longer and wider, but the same height (roughly). It will not fit an X-90 or SWB vit easily.
Peter
Post Posted: Thu Jul 29, 2010 9:49 pm
How does it like being fitted into a LWB NT.
Post Posted: Thu Jul 29, 2010 10:52 pm
I will be running a lwb vit 2L v6 tank.. In a lwb sierra though. Crossmember moved, new mounts, and cut floor out if no BL.
Users browsing this forum: Google [Bot] and 337 guests
