It is currently Wed Oct 28, 2026 9:57 pm
Post Posted: Fri Jul 30, 2010 7:10 am
Hey fellas im currently doing a a engine conversion of a 97 vitara 1.6 EFI into a sierra and need some help with the wireing, ive started sorting through the wires and cut some off that i didnt seem to need. :?
The main thing that i dont have a clue about is how to get the speedo in the sierra working and people talk about a 'VSS' 8O .
Also how do you put up pictures cause i tried and failed haha :roll: :D
Post Posted: Fri Jul 30, 2010 7:15 am
If you are using the Sierra dash and Sierra transfer case then the conversion won't effect the speedo at all.
The VSS is used to give information on the speed to the ECU. Its not required, and your car will work without it, but the ECU will throw codes, and from what I gather your economy at highway speeds will suffer...
I want my old sig back :(
Post Posted: Fri Jul 30, 2010 7:19 am
Oh ok, so if i atach the vss to the ecu but just put it out of the way that would work? and just keep the old speedo then.
Cheers for reply
Post Posted: Fri Jul 30, 2010 7:22 am
AFAIK the VSS runs off the speedo... I'm not sure on all the details as I haven't done this conversion (yet).
There are a couple of good threads on DIY VSS somewhere in the fabrication section...
Post Posted: Fri Jul 30, 2010 7:28 am
ok cheers mate
Post Posted: Fri Jul 30, 2010 7:29 am
Have a look in here for VSS stuff
http://auszookers.com/index.php?name=Fo ... ic&t=10144
http://auszookers.com/index.php?name=Fo ... ic&t=10121
Post Posted: Fri Jul 30, 2010 8:21 am
Sweet, thanks mate
Post Posted: Fri Jul 30, 2010 8:28 am
Hawky4X4 wrote:
Sweet, thanks mate
No worries :P
Users browsing this forum: No registered users and 316 guests
