It is currently Wed Oct 28, 2026 9:40 pm
Post Posted: Wed Aug 04, 2010 6:49 am
So, my water pump is leaking on my 95 LWB Vitara. A mechanic has told me it's not just the seal, but the water pump needs replacing.
Any idea how much this would cost, and is it an easy job to replace?
Regards,
Ranga
Post Posted: Wed Aug 04, 2010 7:27 am
Replace it and the Timing Belt at the same time if it due to be done or even close
Steve W
Post Posted: Wed Aug 04, 2010 7:31 am
Thanks - how much for both of these, and how hard/long to fit?
Regards,
Ranga
Post Posted: Wed Aug 04, 2010 7:42 am
mate, I picked up a timing belt kit for my 94 Vit,(with tensioner and seals), for $68 from Peps, and I've seen water pumps on the net for about $50.
Post Posted: Thu Aug 05, 2010 1:56 am
Local parts dealer wants $80 for the water pump and $120-$140 for the timing belt kit. As per usual, much cheaper on eBay, but not sure of the quality. Reckon I should pay the extra?
Regards,
Ranga
Post Posted: Thu Aug 05, 2010 2:20 am
make sure the pump is a GMB and the belt a Gates and youll be apples
Given it takes a few hours to do, you only have to do em every 100k and either failing can lead to engine failure its worth spending the extra to get the good parts
Post Posted: Thu Aug 05, 2010 2:30 am
Vitara engines are non-interference arent they?
Still, don't want to have to replace it early when an extra $40 could save a few extra hours of work.
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Thu Aug 05, 2010 2:50 am
I've tracked down a GMB pump for $59, and a Goodyear belt and GMB bearing in a kit for $79.
Pays to shop around!
Regards,
Ranga
Users browsing this forum: winchzook and 287 guests
