It is currently Wed Jul 29, 2026 5:28 pm
Post Posted: Fri Aug 06, 2010 7:00 am
so it been tempting me for a while, so it now is getting looked at, so here goes.
My plan is to take a WT sierra (1993) rear diff and 3rd member housing, and put it into a vitara front anvil housing and replace the ring and pinion of that of a sierra, off the vitara. On the way, making up a bracket to weld onto the sierra 3rd member to mount to a calmini 3rd member diff housing mount. The allows for a cheaper locker to be installed in the front, and cheaper parts further down the track.
But i have a few questions for the guru's
firstly is it possible?
can the ring and pinion be taken from a vitara and put on a sierra?
Can the sierra 3rd member be welded to?
if worse comes to worse, can a sierra diff be placed inside a vitara 3rd member?
Thats all i can think of at the moment.
also, if someone has a 26 spline short shaft that they are happy to sell, PM me :wink: .
cheers.
will find out if it fits into a anvil housing soon enough.
Post Posted: Fri Aug 06, 2010 7:46 am
a sierra hemisphere will fit in the vid diff it needs couple mm taken off for the rhs cv to go in
im runing sierra hemisphere sierra side gears and sierra lockright in my gv carrier
i have seen the sierra carrier being used though i think it needs a bit taken off the bottom and plated up have a look on zukiworld there is a bit on there about doing it
Users browsing this forum: No registered users and 515 guests
