| front wheel seals replacement https://auszookers.com/forum/viewtopic.php?f=5&t=14279 |
| Author: | sbbunno [ Thu Aug 12, 2010 10:46 am ] |
| Post subject: | front wheel seals replacement |
whent wheelin the other day with my bro , dad and uncle when i got home noticed a leak coming from my front right hub right where it joins the diff i think its the seals im no to flash with naming the parts i'm fairly good mechanicly and think i can do it myself BUT just incase is there anything i should know or any tips all feedback will be appreciated thanks |
| Author: | steak_knife [ Thu Aug 12, 2010 10:51 am ] |
| Post subject: | Re: front wheel seals replacement |
You axle seal's leaking into the swivel hub, you'll need swivel hub kit.. |
| Author: | Zook_Fan [ Thu Aug 12, 2010 10:57 am ] |
there a bit of a bitch to do. there might be a trick to it but for me putting the rubber seal on, holding it there while aligning the felt seal and the two metal retainers was quite painful. |
| Author: | steak_knife [ Thu Aug 12, 2010 10:59 am ] |
Zook_Fan wrote: there a bit of a bitch to do. there might be a trick to it but for me putting the rubber seal on, holding it there while aligning the felt seal and the two metal retainers was quite painful.
You need to have your tongue to the left a bit.. |
| Author: | sbbunno [ Thu Aug 12, 2010 11:01 am ] |
gettin the kit shouldnt be a prop me and my old man will be workin on it as we'v never done one before if all else fails we'l get someon in but untill then we'l give it a shot and put pics up later |
| Author: | Fatzook [ Thu Aug 12, 2010 11:01 am ] |
1Hr 25 per side is my best effort. That includes cleaning parts, packing bearings by hand, and repacking CV joint. Also sealing all surfaces together with gasket goo Felts are easy once you get the knack |
| Author: | Zook_Fan [ Thu Aug 12, 2010 11:03 am ] |
i did that, then i hit my head on the edge the flare, then i swore and eventually after that process was repeated quite a few times it was done |
| Author: | steak_knife [ Thu Aug 12, 2010 11:06 am ] |
sbbunno wrote: gettin the kit shouldnt be a prop
me and my old man will be workin on it as we'v never done one before if all else fails we'l get someon in but untill then we'l give it a shot and put pics up later There is a good wright up in here on doing them.. Not to hard to do, if you can do a wheel bearing you should be able to do that.. |
| Author: | sbbunno [ Thu Aug 12, 2010 11:13 am ] |
sweet stuff im pretty confident in taking things apart and workin with it cheers sounds like a go ahead to me |
| Author: | Zook_Fan [ Thu Aug 12, 2010 11:26 am ] |
taking it apart really isn't a problem, getting stuff together is a lot harder to get right |
| Author: | 31zook [ Thu Aug 12, 2010 6:59 pm ] |
I don't know how many times i've done this, but i can pull it apart and get it back together, but the disk brake now hits the caliper holder.... me the retard also, it takes me 30mins to pack and finish front wheel bearings |
| Author: | Tonka4 [ Mon Aug 16, 2010 9:49 am ] |
just wondering what's an average price you'd pay for a swivel front hub kit, and where would you get it from Thanks |
| Author: | Zook_Fan [ Mon Aug 16, 2010 10:22 am ] |
ebay, bout $80. more for more seals and stuff |
