| noise sierra https://auszookers.com/forum/viewtopic.php?f=5&t=14319 |
| Author: | salih [ Sat Aug 14, 2010 9:32 am ] |
| Post subject: | noise sierra |
hey all my rear diff had a crack in it so the oil got out and killed the rear diff. so i welded up the hole and put a diffrent diff centre in it. then when for a drive and now the sierra is very very noise as soon as you get to 50kms you cant hear your sellfs think from the back. and when your slowing down its very windy. any ways just thinking if i put a new diff center will this fix the problem ? all my mates think its my diff. ps: if any body has a wide track diff center in melbourne plz pm me thanks |
| Author: | steak_knife [ Sat Aug 14, 2010 9:58 am ] |
| Post subject: | Re: noise sierra |
I'd go with diff, but your wheel bearing's may be upset from being upset, when you pull the axle's out again, turn the bearing's in your hand, you should be able to feel if thay are buggered.. |
| Author: | salih [ Sat Aug 14, 2010 10:12 am ] |
meow ! yeah thanks man il try that what i was going to do tomorow or monday is put the back on a jack and put it into gear let it dirve and listen to the diff see if its the diff for shore. if it is the diff can i get mine rebuilt or am i better just buying another diff centre. because when i looked at this diff center it dident look lie the was any thing wrong with it |
| Author: | steak_knife [ Sat Aug 14, 2010 10:26 am ] |
You could keep getting noisy one's, re build if you can, not always needed tho.. Diff can look "fine" but the case hardening could be damaged or worn on the bearing's, caused from shit oil or mud mud's slippery, but for some reason bearing's don't run on it!! |
| Author: | salih [ Sat Aug 14, 2010 10:41 am ] |
steknig wrote: mud's slippery, but for some reason bearing's don't run on it!!
lol tell me about it |
| Author: | Jester [ Sat Aug 14, 2010 11:18 am ] |
you still have a properly matched crownwheel and pinion? |
| Author: | salih [ Sun Aug 15, 2010 1:30 am ] |
im going to take it to my mate on monday he going to see if it is fukt and if it is i got a guy on here that can sell me a rear centre |
