It is currently Fri Oct 30, 2026 5:39 pm
Post new topic Reply to topic  [ 30 posts ]
Post Posted: Mon Aug 23, 2010 10:06 pm
Hey Guys
Currently doing a G13b conversion into my sierra and now I need an exhaust. Does anybody know if the G16b headers will fit?
Thanks
Post Posted: Mon Aug 23, 2010 10:46 pm
think ive been told exhust ports are different g13 is ovel/sqaure and g16 i think i was told is round. could be wrong.
Post Posted: Tue Aug 24, 2010 12:13 am
u will need custom extractors..
ok thats a lie.. u need a set of sierra extractors with a gti flange.. i have also been told its the sameflage pattern but upside down.. not 100% on that tho.
Post Posted: Tue Aug 24, 2010 10:31 am
So G13b ports are round, G13a/ab are oval, so would I be better off modifying vitara G16 extractors or sierra extractors?
Post Posted: Thu Aug 26, 2010 12:26 am
sierra extractors (cut this off)
extractors with gti flange plate welded on
painted and bolted on engine
You need sierra extractors to clear the engine mount. The sierra ones are a bit of an oval shape but I flared them with an exhaust flaring tool but you probably wouldnt need to.
Post Posted: Thu Aug 26, 2010 1:22 am
These are the first 4-1 on a suzi that I have seen, normally 4-2-1, have you tried the 4-2-1 and if so, how do they compare to the 4-1.
Post Posted: Thu Aug 26, 2010 7:17 pm
Ive been told the 4-1 are better at high revs and the 4-2-1 are better at lower revs. Havent tried the 4-2-1s but these work great though!
Vehicle: LJ50 , LJ80Q-II
Post Posted: Sun Aug 29, 2010 10:28 pm
I like the VL engine mounts 8)
what pully is that you have on the bottom main of the engine? Twin multi V is what i need for my conversion
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Aug 30, 2010 2:33 am
Post Posted: Mon Aug 30, 2010 2:40 am
oh, you can buy them here: http://bdmotorsports.net/product_info.p ... cts_id=443 but they are $150.
Should be cheaper to cut our own.
Post Posted: Mon Aug 30, 2010 3:31 am
Hey neofitou,
I'm in Bendigo (currently working in Melbourne), your welcome to come for a look if you want. I'm almost finished my conversion, I just need an exhaust and to do a bit of tidying up.
Can you get us a price to get two cut?
Thanks
Post Posted: Mon Aug 30, 2010 5:11 am
no worries with the pricing, I should have mentioned before, mine is a MK1 engine and the shape is different from a Mk2/3 one. I will bring in the gasket and scan it tomorrow and then do the cad in the next few days.
If yours is a Mk2 or 3 it will be useless to you though.
I might take you up on the offer of taking a look at your conversion. But not for a few weeks (after other zuk projects). Thanks.
Post Posted: Mon Aug 30, 2010 7:57 am
just on the flange- I got mine brand new from a place in qld, it was either $35 or $70 and it came with a gasket. (mk2 and 3- cant see why mk1 would cost any more.
Post Posted: Mon Aug 30, 2010 8:52 am
Cool. Well we should get it from there then. Details?
Post Posted: Mon Aug 30, 2010 9:11 am
yeah definately- my mate ordered it for me so Ill ask him where he got it from!
Post Posted: Mon Aug 30, 2010 9:15 am
haha, yeah thanks, the stock sierra mounts were absolutely stuffed!
It was just the pulley on the mk2 gti engine but it did have air con so it might have been from that
Post Posted: Mon Aug 30, 2010 9:30 am
My Gti is a mk2 and I have a mk3 in the shed and they're both twin multi (4pk) rib harmonic pulleys (good for a power steering conversion :).
I've had a few exhaust flanges laser cut, for my zook, for the various turbo manifolds I've made. I found some exhaust shops that make custom extractors (not off the shelf jobbies) will usually have them, around the $50-$70 mark. I however needed input and dump flanges etc too, so I just got my bro to do cad's up and emailed them off, cost me bout $70 for 8 flanges (my bro got some for his project too).
I reckon I've got the dxf files on my computer, if not my bro can email them, they were made to the same specs as the gasket.
Post Posted: Mon Aug 30, 2010 9:49 am
be keen to see this conversion mate, and good to see another bendigo zook on the forum!
Post Posted: Mon Aug 30, 2010 10:26 am
Mine's a Mk3, but thanks anyway neofitou. Hopefully I'll be finished soon, then I can show off the conversion.
I'll take cad files if you can find them sleeperzook, cheers.
sound like the one fifty from bdmotorsports.net/prod...cts_id=443 is a bit steep, hopefully I can get it a bit cheaper.
that pulley is from the AC
Post Posted: Mon Aug 30, 2010 12:46 pm
I got it from my brother. PM me your email address and I'll forward it to you.
Just a word of warning, some laser cutting places have a min charge, so depending who you go to, prices may vary a lot. I got mine out of 10mm mild, I wouldnt go any thinner because if you warp it when you weld it you will want some fat to mill off. Best way would be to pre and post heat when welding, or have a spare donk like me and weld it on the engine :)
Post Posted: Tue Aug 31, 2010 10:17 am
Mine is a Mk1 Gti and has a multi v inner and single v outer pully, further research on RedlineGti has indicated that pully was changed on the mk2/3 to the twin multi setup.
At least i know what im looking for know.
Post Posted: Wed Oct 06, 2010 2:21 am
I finally got my exhaust made up, details for those who are looking to do this conversion
the headers were these:
http://cgi.ebay.com.au/SUZUKI-SIERRA-DR ... 500wt_1154
and the flange was made up by http://www.onlinelaser.com.au/ from sleeperzook's CAD file - thanks mate. Cost me about $80
but I wouldn't recommend those header as they fouled on the engine mount and needed a bit of hammer work to make them fit.
Post Posted: Wed Oct 06, 2010 2:35 am
oh and does anyone know if the location of the o2 sensor is important?
I have a 4-2-1 so does it need to be feed by all 4 cylinders?
Thanks
Post Posted: Wed Oct 06, 2010 2:51 am
:shocked:
Post Posted: Wed Oct 06, 2010 3:12 am
Thanks
Im not sure, but the few cars that I have had that are injected all have the 02 sensor where all the cylinders feed it.
Maybe its ease of manufacture, maybe its most important, me, Id go for all.
IF there is 1 or 2 cylinders involved, then the others can do as they want with no control.
Vehicle: '92 Sierra
Post Posted: Thu Oct 07, 2010 3:42 am
Thanks
x2. I'd be trying to get the sensor in a position that it gets the mix from all cylinders. Gives you the best average of the fuel/air ratio that the engine is running. All the ones I've seen have been right before the cat. Do you know if the o2 sensors are heated (3 wire i think) on the GTI engines or is it the exhaust gas that gets them up to temp (2 wire I think)
Post Posted: Thu Oct 07, 2010 7:07 am
fyi for others doing this conversion, I got a quote from MPH from ebay:
Suzuki Sierra Headers with Suzuki GTI Mk1 Flange $250 delivered you can order on 0413745661 cheers Rod
- rod_mph
I think that should be the go, Im not going to bother making my own anymore.
Post Posted: Fri Oct 08, 2010 12:31 am
ahh I should have tried MPH, that's much easier than getting them made bit by bit.
Any feed back on the O2 cell location from guys that have done the conversions? Its a single wire cell. I have done some googling and some people seem to have trouble with the single wire cell not getting hot enough, when they are further away from the engine.
Post Posted: Fri Oct 08, 2010 12:53 am
oh and it will run ok with out the O2 sensor right? Its just there for cruising economy right?
Post Posted: Fri Oct 08, 2010 9:45 pm
you want the o2 sensor, drill a large hole in the extractors and get your exhaust shop to weld the nut on so you can put the sensor in.
my o2 sensor is just where the 4 pipes become 1..
Users browsing this forum: No registered users and 84 guests
