It is currently Sun Nov 01, 2026 11:40 am
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Mon Aug 30, 2010 2:37 am
I've been trying to find out what the Diff Ratios would be on the "early 4cyl model MAN & AUTO" GV's up to about '02 or there abouts....
Is there a difference between the MANUAL and AUTO 4cyl versions??
So far I've found the following:
4.625:1 for 2.0ltr MANUAL (I assume this is for the 4cyl motor)
4.88:1 for 2.0ltr AUTO (I assume this is for the 4cyl motor)
Can anyone in the know confirm if this is right....?
plus..... When did they start bringing out the STEEL Diff's in the Front + I believe the AUTO model's can have Reduction Gears installed where as the MANUALS cannot.... is that right??
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Mon Aug 30, 2010 8:24 am
I have in my 99 GV 5.125:1 front and rear diffs out of a short wheel base soft top Grand Vitara cant remember the year but definitely out of a GV.
The front had the ADD diff in alloy housing which i installed into my steel housing.
The rear was a direct fit but the housing looked different as it had strengthening ribs around the pinion area due to the smaller pinion (no ball pivot mount as it is from a GV.
Post Posted: Mon Aug 30, 2010 8:28 am
I didn't think any GV's came with 5.12's..... was it only in SWB's
Post Posted: Mon Aug 30, 2010 8:46 am
It was a SWB GV i think it was 1.6 manual but cant be sure.
I don't know the year but the vin of the wreck was JSAFTA03V00201329.
Like i said the rear diff carrier is the GV style without the upper control arm mount and the casting is vastly different to the 4.3:1 carrier it replaced with extra ribbing running from the pinion area towards the mounting flange.
Post Posted: Mon Aug 30, 2010 8:55 am
really, i didn't think that was a factory ratio for the GV?
I know experament-u2 put 5.12:1 vitara diffs in his 1.6 GV soft top
Post Posted: Mon Aug 30, 2010 11:28 am
Yep 41 x 8 (5.125:1) out of a GV......
Unless they were not aboriginal to that vehicle but the rear carrier is a non control arm mount type and the R&P definitely belong in the carrier as there is a sticker on it with model number and "41M" just as the 4.3:1 carrier I removed has the same sticker but with "43M".
Post Posted: Mon Aug 30, 2010 2:35 pm
nice SCORE, was it still an alloy front diff?
Post Posted: Tue Aug 31, 2010 8:00 am
Yes it was the air disconnect type with alloy housing that but i swapped the R&P into my steel GV housing.
Post Posted: Tue Aug 31, 2010 8:53 am
It seems like the 4cyl (2.0ltr) MANUAL GV's are the only ones that have the ability for Reduction Gears..... according to the Calmini Site.....
Users browsing this forum: No registered users and 454 guests
