It is currently Fri Oct 30, 2026 12:07 am
Post Posted: Tue Aug 31, 2010 9:58 am
Hey guys i have a few queries regarding a g16b-sierra converson i am about to start. I know there are countless threads on here about this subject but all the info seems to get diluted. So here goes...
I am looking at buying a 2000 model baleno with the manual box.
What i would like to know is.
Will my extractors from my 8v 1.6 fit this engine ?
In relation to the attched picture, what is the deal with these cooling hoses/ protrusion from the block ? will this interfere with the firewall ?
What fuel pressure is required ? i was looking at runnign a 2l external surge tank with an inline lo pressure pump to it then an inline hi press pump to the motor. Will this setup work ? will i need a fuel pressure regulator ?
Do the sierra cooling hoses work ?
http://www.facebook.com/album.php?aid=2 ... =fbx_album (in the red square)
Anything else trouble wise you think is worth mentioning please do.
Thanks heaps in advance
Jonny
Post Posted: Tue Aug 31, 2010 10:07 am
Will my extractors from my 8v 1.6 fit this engine ? NO
In relation to the attched picture, what is the deal with these cooling hoses/ protrusion from the block ? will this interfere with the firewall ? YES
What fuel pressure is required ? i was looking at runnign a 2l external surge tank with an inline lo pressure pump to it then an inline hi press pump to the motor. Will this setup work ? YES will i need a fuel pressure regulator ? THERE IS ONE ON THE FUEL RAIL ALREADY
Do the sierra cooling hoses work ? NOT REALLY
Jonny
Post Posted: Tue Aug 31, 2010 10:16 am
So will the 16v vitara extractors work ?
Can anything be done about these pesky cooling hoses on the back of the motor ?
so i can run any external efi pump ?
and what parts are required to plumb the 1.6's cooling system into the radiator ?
cheers
Post Posted: Tue Aug 31, 2010 10:18 am
& if you get a conversion kit from the state's, just remember when thay say passenger side eng mount, it's our driver's side..
:roll: Took me age's to figure that out.. :wink:
Post Posted: Tue Aug 31, 2010 10:21 am
straty wrote:
So will the 16v vitara extractors work ? YES
Can anything be done about these pesky cooling hoses on the back of the motor ? YOU WILL NEED TO MAKE A 90* ADAPTOR
so i can run any external efi pump ? YES. STICK WITH SOMETHING COMMON. THAT WAY SPARES ARE EASIER TO COME BY. VL COMMODORE PUMP IS A POPULAR CHOICE
and what parts are required to plumb the 1.6's cooling system into the radiator ? WHAT CONDITION IS YOUR RADIATOR IN?
cheers
Vehicle: 1987 sierra tray back buggy
Post Posted: Tue Aug 31, 2010 10:25 am
Can anything be done about these pesky cooling hoses on the back of the motor ? yep the one your worried about is the thermostat housing get rid of it and put a right angle on there or bash the firwall.
so i can run any external efi pump ? yep you can or if you are getting the whole car use the baleno swimmer
and what parts are required to plumb the 1.6's cooling system into the radiator ? i cant answer that my rads on the back and we used 10 bar oil suction water hose
cheers
Post Posted: Tue Aug 31, 2010 12:21 pm
ok thanks a lot for your help guys. ummm i dont thik i will have to worry about a conversion kit as i already have an 8 valve 1.6 in mine so i shuld be able to use the kit already in it ?
Post Posted: Tue Aug 31, 2010 12:40 pm
Correct :wink:
Users browsing this forum: Google [Bot] and 142 guests
