It is currently Thu Oct 29, 2026 12:39 pm
Vehicle: 99coily , some mods but not as
Post Posted: Sat Aug 28, 2010 2:05 am
help please !
hello all this is possibly an old question but ... i couldn't get an answer on any of the old topics.
so here goes .
i am replacing the the starter motor in my 96 sierra , BUT the bottom bolt has stuck fast and is rounding out it's head .
i have plenty of tools , a good mechanical background and so any suggestions will be gladly accepted . till then it will have to sit on it,s axle stands .
Post Posted: Sat Aug 28, 2010 2:09 am
pretty rare issue.. i have the other way.. mine constantly falls out.. i think i am on my 5th..
u could try pulling the intake manifold off and might make access easyer?
Vehicle: MY2019 Jimny
Post Posted: Sat Aug 28, 2010 2:17 am
Access to a welder? You might be able to get underneath and weld a nut to the head of it...
Post Posted: Sat Aug 28, 2010 2:18 am
Do you have hex hed sockets, impact driver ones, often this will hold while other wont.
Post Posted: Sat Aug 28, 2010 3:07 am
six sided socket, or a quick zap with the oxy, or loctite frezze your nut's off.... tap it with a small hammer then go for it....
Post Posted: Sat Aug 28, 2010 3:35 am
thanx , but as jonno has said the reason his bolt comes loose is that he didn't have the ken idiot who has obviously loctited this bolt in ! have a welder and lpg kit but not to keen as the fuel delivery hoses are about 50mm away . am also using an impact socket on a breaker bar so i now know for sure ken idiot has been at work with his loctite . will have to think this thru again .
thanx again
Post Posted: Sat Aug 28, 2010 4:00 am
Simply wrap the hoses in some wet rags. there is no vapours so all your concerns are with heat transfer wrecking the lines.
I do oodles of welding this way in tight roof spaces with oxy/acetelyne.
Post Posted: Sat Aug 28, 2010 5:40 am
X2
move or wrap up hose and if your worried do It with a fire extingisher handy
Post Posted: Fri Sep 03, 2010 11:18 am
many thanks for all your suggestions . tried welding a bolt to the locked one , but weld broke before anything happened .
then the previously installed immobiliser decided that i wasn,t allowed to start the car........
$245 later the immobiliser was removed and the starter replaced ( die grinder to cut through bracket and break off from mount , closed eyes and walked away ) . when the bolt came out was caked in loctite .
ken idiot would have been proud, $500 for 2cents worth of loctite .
Users browsing this forum: Google [Bot] and 396 guests
