| Whining noise https://auszookers.com/forum/viewtopic.php?f=5&t=14721 |
| Author: | milkhunter [ Wed Sep 01, 2010 4:31 am ] |
| Post subject: | Whining noise |
Hi guys. Car is a 98 sierra. I have this whining noise coming from the engine. I thought it might have been the air con compressor, because i just had a mate regas it before we went to kakadu last weekend. It was the only thing that has been touched recently. So i took the belt that drives the compressor off and fired it up. Same result Then i took off the fan belt and gave it another shot, this time no noise. Problem now is that i don't know if it is the water pump or alternator. Tried spinning each of them by hand but i can't really tell. Has anyone had this problem? or is there something else i can do to rule out one or the other? |
| Author: | MacDaddy [ Wed Sep 01, 2010 6:08 am ] |
| Post subject: | Re: Whining noise |
milkhunter wrote: Hi guys.
Car is a 98 sierra. I have this whining noise coming from the engine. I thought it might have been the air con compressor, because i just had a mate regas it before we went to kakadu last weekend. It was the only thing that has been touched recently. So i took the belt that drives the compressor off and fired it up. Same result Then i took off the fan belt and gave it another shot, this time no noise. Problem now is that i don't know if it is the water pump or alternator. Tried spinning each of them by hand but i can't really tell. Has anyone had this problem? or is there something else i can do to rule out one or the other? If its a bit like a squealing whine, then i would say water pump... try spraying some CRC or WD40 around the centre of the fan and Alt to see if that stops the noise, do one first, then try the other... but i would think it is water pump... |
| Author: | lump_a_charcoal [ Wed Sep 01, 2010 8:16 am ] |
Have you checked to see if someone's wife is stuck under your bonnet? |
| Author: | Llewellyn92 [ Wed Sep 01, 2010 8:25 am ] |
| Author: | sierrajim [ Wed Sep 01, 2010 12:45 pm ] |
Does it have power steering? if it does could be low on fluid. |
| Author: | Dale [ Wed Sep 01, 2010 2:03 pm ] |
Have you checked them for play? Not just spinning them? |
| Author: | milkhunter [ Thu Sep 02, 2010 5:47 am ] |
Thanks for the relies guys. A mate came around today (a mechanic) and put the stethescope (spelling) on it and its deffinately the water pump. While im in there i might as well do the alternator upgrade as well. Now i just have to find them, will be checking the wreckers tommorrow. Thanks again |
| Author: | Jccck [ Thu Sep 02, 2010 5:51 am ] |
milkhunter wrote: Thanks for the relies guys. A mate came around today (a mechanic) and put the stethescope (spelling) on it and its deffinately the water pump.
While im in there i might as well do the alternator upgrade as well. Now i just have to find them, will be checking the wreckers tommorrow. Thanks again Stethewhateverscope hey I saw a mechanic put a long flatblade screwdriver onto areas of the engine once, with the handle to his ear It seemed to work, and was amusing to see |
| Author: | lump_a_charcoal [ Thu Sep 02, 2010 5:53 am ] |
until it hits a fan blade... |
| Author: | Jccck [ Thu Sep 02, 2010 5:54 am ] |
lump_a_charcoal wrote: until it hits a fan blade...
Like i said, amusing to see lol |
