It is currently Fri Oct 30, 2026 7:37 am
Post Posted: Thu Sep 02, 2010 2:59 am
Does it just slip off or do i have to undo the ?17mm? main crank bolt?
I cant remember, i have done it before, but it was years ago.
My pulley has the teeth parts for the crank sensor for a Baleno motor.
Trying to replace the crank seal down there.
Any help would be great, Thanks.
Post Posted: Thu Sep 02, 2010 3:06 am
5 X M6 bolts(10mm head) hold the pulley on and one M12 (17mm head)holds the bottom belt drive on.
Post Posted: Thu Sep 02, 2010 3:10 am
Ok, thats what im after. My 5 small bolts were 8mm socket heads. Like the top cam cover.
Time to get her in lowrange and in gear with a big hammer on a spanner! :lol:
Thanks
Post Posted: Thu Sep 02, 2010 3:42 am
not low range, high range 5th
Post Posted: Thu Sep 02, 2010 3:51 am
Thanks
Mine are 8mm too now I think about it :oops: but mine are hex heads not socket heads.
Post Posted: Thu Sep 02, 2010 6:39 am
ok will try 5th..
I meant hex heads - 8mm socket.
Users browsing this forum: No registered users and 310 guests
