| G16B Bottom crank/timing pulley question. https://auszookers.com/forum/viewtopic.php?f=5&t=14751 |
| Author: | BlueSuzy [ Thu Sep 02, 2010 2:59 am ] |
| Post subject: | G16B Bottom crank/timing pulley question. |
Does it just slip off or do i have to undo the ?17mm? main crank bolt? I cant remember, i have done it before, but it was years ago. My pulley has the teeth parts for the crank sensor for a Baleno motor. Trying to replace the crank seal down there. Any help would be great, Thanks. |
| Author: | want33s [ Thu Sep 02, 2010 3:06 am ] |
| Post subject: | Re: G16B Bottom crank/timing pulley question. |
5 X M6 bolts(10mm head) hold the pulley on and one M12 (17mm head)holds the bottom belt drive on. |
| Author: | BlueSuzy [ Thu Sep 02, 2010 3:10 am ] |
Ok, thats what im after. My 5 small bolts were 8mm socket heads. Like the top cam cover. Time to get her in lowrange and in gear with a big hammer on a spanner! Thanks |
| Author: | royce [ Thu Sep 02, 2010 3:42 am ] |
not low range, high range 5th |
| Author: | want33s [ Thu Sep 02, 2010 3:51 am ] |
BlueSuzy wrote: Ok, thats what im after. My 5 small bolts were 8mm socket heads. Like the top cam cover.
Time to get her in lowrange and in gear with a big hammer on a spanner! Thanks Mine are 8mm too now I think about it |
| Author: | BlueSuzy [ Thu Sep 02, 2010 6:39 am ] |
ok will try 5th.. I meant hex heads - 8mm socket. |
