It is currently Mon Nov 02, 2026 12:50 am
Post Posted: Mon Sep 06, 2010 5:33 am
Before you all say "search" I have looked here's example
the question wasn't answered at the bottome
http://auszookers.com/index.php?name=Fo ... lex+issues
what I would like to know is without doing ruf how can I fix this.
I run 31" mudzillas if I remove shackles I will need a bodylift is this correct?
Sorry if this has been covered but I have searched and everything
leads to ruf which I don't really want to do.
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Mon Sep 06, 2010 5:38 am
yes you will need a BL or some guard modifying. wat springs do you have in, longer springs will increase (ie fix) your vertical shackle angle.
Vehicle: 93 Sierra
Post Posted: Mon Sep 06, 2010 5:41 am
Reads like you have 2" shackles with stock'ish springs. If so, it's the extra length on the shackle that is causing the problem.
Going back to stock'ish shackles or fitting longer springs will help. 31's will definitely not fit with stock springs, stock shackles and no body lift. Body lift + seam bashing might get you there (depending on the specific tyres, rims and springs you're running) but may still scrub slightly.
Take a photo of front corner of car so we can see how it sits - will be easier to make suggestions then.
Post Posted: Mon Sep 06, 2010 5:52 am
Has 2" lifted springs thought I wrote that will take photo of it now
Post Posted: Mon Sep 06, 2010 6:08 am
the issue is some leaf manufacturers dont lengthen the leaves when they arc them up for the 2" lift - this means the length shortens and shackle angle decreases.
If you're after just a better shackle angle you can redrill the perches back a bit, but not much.
Post Posted: Mon Sep 06, 2010 6:11 am
Post Posted: Mon Sep 06, 2010 6:32 am
Stock shackles required.
Post Posted: Mon Sep 06, 2010 6:35 am
If I go back to stock I should bl if then?
Post Posted: Mon Sep 06, 2010 6:37 am
Probably. Might even be cheaper than bumpstop extensions!
Post Posted: Mon Sep 06, 2010 9:20 am
Going to body lift and get some standard shackles thanks for the help
Post Posted: Mon Sep 06, 2010 9:25 am
a stock zook can fit 31s with only 25mm bump stop extensions and the front diff moved forward 20mm...
Post Posted: Mon Sep 06, 2010 9:31 am
do all sierras have bump stops in the front? i dont seem to have any in mine and i got it as some stocker granny car. had like 205lt or some tire size i never heard of and a sway bar still in but seems to have no bump stops
Post Posted: Mon Sep 06, 2010 9:36 am
Tyres would scrub wouldn't they 31zook?
Taszook it should have bumpstops.
Post Posted: Mon Sep 06, 2010 9:55 am
sorry to hijack but i've always wondered if i had bumpstops missing. this is about where they would be?
Post Posted: Mon Sep 06, 2010 10:23 am
yer man no bump stops there... bad idea 8O
Post Posted: Mon Sep 06, 2010 10:31 am
hmm the guards stop the wheels going up to far anyways xD thats what i could never figure out, why would a bog stock, never seen dirt sierra have no bump stops. why is it a bad idea? what damage can i cause?
Post Posted: Mon Sep 06, 2010 10:45 am
worldo wrote:
looks like every other sierra with lifted springs and longer shackles to me, dont worrry about and enjoy life
Post Posted: Mon Sep 06, 2010 11:00 am
[quote="taszook"]hmm the guards stop the wheels going up to far anyways xD thats what i could never figure out, why would a bog stock, never seen dirt sierra have no bump stops. why is it a bad idea? what damage can i cause?[/quote
Its anyone's guess as why the bumps are missing either way you need to get some.
You can damage the shocks, bend shock mounts and uncool shit like that.
Post Posted: Tue Sep 07, 2010 7:38 am
yes and no, dumpy hammer will do the trick buddy
it will look like this
these are 31X10.5s, if you dumpy the sill's (i didn't have to, but this prob's had more to do with the lack of sill due to rust) cut off your wing's and your out :D
Users browsing this forum: No registered users and 66 guests
