It is currently Fri Oct 30, 2026 6:00 pm
Post Posted: Tue Sep 07, 2010 11:46 pm
My fathers vitara has just had a set of Bruces spring inserts (15 front and 30mm rears) put in, and a set of new tyres, 235/75s, the wheel aligner tells him that the caster is out, err? also the camber.
I can understand the camber, but the caster, it came up level, neither higher at the front or rear.
I thought they could alter camber, but dad was told no, only toe in.
So, what do ya do, I have heard of caster kits, shims, but how on earth do you know how many degrees, or is it suck n see, and camber??
Post Posted: Wed Sep 08, 2010 12:05 am
get some camber adjustment bolts from repco or pedders.
Post Posted: Wed Sep 08, 2010 12:10 am
Joe, I put in adjustable camber kit on the back of my statesman, are these similar, offest bolts sortof.
Post Posted: Wed Sep 08, 2010 12:41 am
yeah they are offset bolts
what readings did they give him? saying it outs jsut a way for them to cover doing a shit job
Post Posted: Wed Sep 08, 2010 1:21 am
I rang the tyre mob, know him pretty well. The camber is ok, its the caster thats out, an only a small bit, Rob recons its not worth money to fix the small prob, a tiny bit out, few hundred to fix.
Its all good, thanks all.
Users browsing this forum: No registered users and 401 guests
