| Noisy Hydraulic Tappets https://auszookers.com/forum/viewtopic.php?f=5&t=14968 |
| Author: | Scrawny [ Wed Sep 08, 2010 9:31 pm ] |
| Post subject: | Noisy Hydraulic Tappets |
I'm after some suggestions on a fix for noisy hydraulic tappets, other than replacement. Has anyone used an oil additive that has shut them up? |
| Author: | shep [ Wed Sep 08, 2010 9:44 pm ] |
| Post subject: | Re: Noisy Hydraulic Tappets |
nulon lifter free worked on my challenger |
| Author: | zookfun [ Wed Sep 08, 2010 9:47 pm ] |
my g13b had noisy lifters when i got it and i tried an additive and it fixed them right up! |
| Author: | want33s [ Wed Sep 08, 2010 10:18 pm ] |
zookfun wrote: my g13b had noisy lifters when i got it and i tried an additive and it fixed them right up!
They have rockers that run on the cam. What engine are you talking about Scrawny? |
| Author: | PJ.zook [ Wed Sep 08, 2010 10:48 pm ] |
My cat was noisy when I lifted it with my foot, so I fed it some Nulon, now it doesnt make a sound... any sound... it may actually be dead... either that or I stink. |
| Author: | Scrawny [ Thu Sep 09, 2010 1:28 am ] |
want33s wrote: What engine are you talking about Scrawny?
It's an 03 Camry, 4 cylinder. Not sure what the engine code is |
| Author: | want33s [ Thu Sep 09, 2010 2:02 am ] |
ScrawnC wrote: want33s wrote: What engine are you talking about Scrawny? It's an 03 Camry, 4 cylinder. Not sure what the engine code is Not 100% sure but I think they are a bucket and shim setup. You'll have to replace the worn shims with ones of the correct thickness to stop the ticking noise. Not easy unless you have feeler gauges, vernier calipers, a bucket/spring compressor and a box full of assorted shims. |
| Author: | Scrawny [ Thu Sep 09, 2010 4:48 am ] |
I might have to pop the rocker cover off and have a look. I've done shims on 1HZ's before. It does sound more like noisy tappets though |
