It is currently Fri Oct 30, 2026 6:07 pm
Post Posted: Sat Sep 11, 2010 2:36 am
decided to rebuid the WT rear diff i got before converting it to NT to suit my SJ40T. First thing i noticed was it had been welded, second thing was the chunks of metal sitting in the bottom of the pumkin. pinion gear and ring chewed out. :roll:
So my question is can i use the ring and pininon out of the NT diff
(1lt SJ40T i used the suzistore data page to find ratio 4.11:1) and put them in/on the center of the WT diff beleive to be out of a SJ70 94 model (suzistore data page 3.7:1 ratio)
Thanks for your help
Post Posted: Sat Sep 11, 2010 2:49 am
no 1 litre and 1.3 gears dont interchange they are a different size
Post Posted: Sat Sep 11, 2010 5:53 am
What he said..
Post Posted: Sat Sep 11, 2010 6:04 am
I have no idea, but my money is on the above two.
Post Posted: Sat Sep 11, 2010 6:10 am
N/t to w/t bolt's on, Lt has a smaller ring & hemisphere, smaller everything really..
If you want under 3.9's(n/t) you will need two vit front ring & pinion's..
same ratio work's best..
Post Posted: Sat Sep 11, 2010 6:44 am
thanks for the replys guys, guess ill be posting in the wanted section now :( was hoping to make some use of the old nt diff before i turfed them.
Post Posted: Sat Sep 11, 2010 6:46 am
dont turf em, parts might jsut help keep somebody elses 30yo zook running :wink:
you could look at a pair of 5.12 as well from a vitara front, might help you if you run bigger tyres too
Users browsing this forum: No registered users and 381 guests
