It is currently Sat Oct 31, 2026 10:41 am
Post Posted: Sat Sep 11, 2010 11:15 am
hey,
for my sierra 88'
what sort of engine do u recomened??????
jimny,vitara, reco sierra, 4k, 4age, 5k?????
any others ?
what bolts straight up and goes hard
Sj80,31 claws, lift, winch, 6.5
Post Posted: Sat Sep 11, 2010 11:57 am
jimny and sierra are the only ones that will bolt up.
do you need extra power? how much more? the 1.6 EFI would probably be plenty. the other three are toyota engines.
Post Posted: Sat Sep 11, 2010 1:19 pm
my 1.6EFI is awesome... infact just today i had a drag race against shandy92 in his vitara with 1.6 carby... by 80km/hr i was around 100m infront of him!
the driveability is just awesome too - soooo much torque compared to the 1.3!
Post Posted: Sat Sep 11, 2010 1:21 pm
I vote for 1.6EFI aswell. :D
Post Posted: Sat Sep 11, 2010 2:07 pm
1.6 carby (use 1.6 bottom end and 1.3 head and manifolds) is easiest and cheapest solution for some more power. Need adapter plate, and to modify oil pick up and 1.3 head gasket and few odds and ends ($250 plus engine). But can bolt up in a day.
1.3 gti is next easiest with highest power from suzuki engines. Although not really suited to offroad. Need to sort out efi, extractors and dizzy
1.6efi from vit is next, more time but easier than the rest. but more power than 1.6 carby. needs adapter plate, modify oil pick up, extractors and efi sorted.
1.6 baleno mpfi or 1.6 spfi is next (adapter plate, extractor, efi sorted, thermo stat outlet, modify oil pick up. Dizzy type needs angled dizzy drive, coil pack needs sump pan cut and shut.
5k needs custom mounts, yota gearbox, modified trans tunnel, modified gearbox - transfer shaft, extractors, sump mods
Probably similar levels of work for the other two yota motors.
1.6 carby if lazy, and 1.6 efi if keen.
Don't underestimate the time taken so sort the efi crap, angled dizzies, and cooling water outlets (on the baleno/swift).
Vehicle: Jeep
Post Posted: Sat Sep 11, 2010 6:54 pm
8O 8O 8O
:roll: :?
:rofl: :rofl: :rofl:
Post Posted: Sun Sep 12, 2010 12:59 am
MacBear wrote:
8O 8O 8O
:roll: :?
There is no comparison between the two. If the vit was efi it would have been a different outcome.
Post Posted: Sun Sep 12, 2010 1:38 am
3rz would be nice... big job thou... but for a bolt up job = cant go past the g16b (1.6 efi)
Post Posted: Sun Sep 12, 2010 3:23 am
the 4age is a great motor, but alot of work to get it in. you will need engine mounts, gear box mount and new transfer mounts. the sump of the 4age is also reversed compared to a sierra, so you will have clearance problems with the diff unless you flip it or push your diff way forward.
Post Posted: Sun Sep 12, 2010 3:28 am
Iused my diff to make room, just jumped bejubes out of it & Bang, clearance!! very bent sump tho
:P
Post Posted: Sun Sep 12, 2010 5:01 am
efi sounds good... any ideas on a half cut price?????? :)
Post Posted: Sun Sep 12, 2010 5:35 am
Normally just buy an engine and harness.
g16b conversions range from $0-$3000. If your doing all the work.
Some people buy wrecked cars, and sell the rest to get their money back.
Post Posted: Sun Sep 12, 2010 5:52 am
Buy a half cut import g16b , You usually get a low km motor with all the bits you need ,even a gearbox and transfer case, which you can sell or keep for when you want to do a Joeblow dual transfer set up. :wink:
Mine was about $2500. but that was a few years ago, so they should be a bit cheaper now..
Post Posted: Sun Sep 12, 2010 7:31 am
shandy92s vitara is efi :wink:
Post Posted: Sun Sep 12, 2010 11:01 am
Thats steep!!!
3 years ago I was getting them for $1400 for a front cut.
Now they are over $1800 and heaps harder to find. supplied must be drying up over in japland. :(
Users browsing this forum: No registered users and 407 guests
