https://auszookers.com/forum/
alternator questions
https://auszookers.com/forum/viewtopic.php?f=5&t=15050
Author:  819FKA [ Sun Sep 12, 2010 10:02 am ]
Post subject:  alternator questions
can u use a bosch alternator insted of mitaubishi when u do the ford alt conversion on a sierra
Author:  Rusho [ Sun Sep 12, 2010 10:08 am ]
Post subject:  Re: alternator questions
Pretty sure you can...how many pins in the back of it??
Author:  89_tintop [ Sun Sep 12, 2010 10:09 am ]
Good question....
I am interested to know so aswell.... I can't remember if they mount the same. I can tell you for sure that the plugs are different.
Author:  steak_knife [ Sun Sep 12, 2010 10:13 am ]
if it's a working alt that internally regulated & you can make it fit & be aligned with the bottom pulley, yes, yes you can..
Author:  royce [ Sun Sep 12, 2010 10:16 am ]
in this case they dont bolt up, youll need to make brackets
Author:  steak_knife [ Sun Sep 12, 2010 10:24 am ]
:P I've got a mig!! :P
Author:  slyvan1 [ Sun Sep 12, 2010 10:28 am ]
i used a bosch one of an eb falcon bolts straight up. it's only a 70 amp. I prefer an external regulator. i had an el 110 amp on it but it didn't like water and the brushes shorted out. if i could have pulled it out and dry'd it, would have been fine.
The capacitor on the back had to get moved to clear my engine mount no big deal, just needed to be re-earthed
(when i said external, i meant it's still in the alternator just at the back where you can remove it with 2 screws very easy to replace regulator and brushes in minutes)
Author:  slyvan1 [ Sun Sep 12, 2010 10:29 am ]
you do need a different plug though, its the bosch injector type plug.
Author:  steak_knife [ Sun Sep 12, 2010 10:41 am ]
Nice editing!! :P :wink:
Author:  819FKA [ Sun Sep 12, 2010 8:15 pm ]
so it sounds like it will work, its so much easier and cheaper gettin a bosch 1, but keep the info cummin i havent bought the alt yet
