It is currently Mon Nov 02, 2026 12:50 am
Post Posted: Sun Sep 12, 2010 11:15 am
Have been attempting to fit a new timing belt on a 13GA as there is no existing belt as a guide I am not sure how to set up timing,It was my under standing that I had to get the no 1 piston at TDC on the compression stroke and the cam pulley on the v mark but when I read the factory manual it shows a picture of the alignment and then has a note that says In this state no 4 piston is at tdc on the compression stroke.
Finding this very confusing can any one please help me to understand the procedure.
Thanks :oops:
Post Posted: Sun Sep 12, 2010 11:18 am
I think there is 2 marks on the crank gear. one is for tdc 4, the other tdc 1. If that makes sense?? It does in my head anyway :P But that is a very fragile environment. I think last time i did it i rotated dizzy 180 degrees to suit when it didn't fire
Post Posted: Sun Sep 12, 2010 3:07 pm
1 and 4 will both be TDC at the same time, but only 1 of them will be on the Comp stroke on the cam. (same with No 2 and 3 cyl).
If it doesn't fire, either rotate the cam 180 deg and re-fit the belt, or as Rusho said rotate the Dizzy. You can be a cheapskate, and just move all the leads on the cap 180 deg.
Post Posted: Sun Sep 12, 2010 8:34 pm
keyway on the crank pointing up to the mark on the housing
keyway on the cam pointing down with teh mark on the pulley lined up witht eh mark on the cover
if you have 2 ways the cam pulley can go on if its on the wrong one it wont rev, there is a thread on here somewhere saying which is the right one but hopefully somebody will come along and say before somebody finds it
Post Posted: Sun Sep 12, 2010 11:09 pm
:) Not too difficult, just make sure you have no 1 piston @ tdc, rotate cam until you see the intakke valve close and the exhaust valve atart to open and that is at the right cylinder for all the action. Next rotate the cam back a little until both rockers are rockin on the bottom othe cam lobe but about to approach the exhaust valve and fit it there. you may need to keep an eye on the cam to see that it has not moved during this process... I hav e not done a suzuki specifically but spent a great deal of my working life building engines. once you hve got to this stage you should find that all the confusing marks begin to make sense, Hope this helps. A thought has just jumped into my head make sure that you do not have the cam drive wheel on backwards, dont know if they can on a suzuki but do know it is possible on some. :wink:
growing old is nature, growing up is choice.
Post Posted: Mon Sep 13, 2010 9:51 am
when you time it up according to the manual , it is on the exhaust stroke of number 1 cylinder , so you need to rotate the crank 180 degrees to get it on the compression stroke of number 1 .
Users browsing this forum: No registered users and 69 guests
