Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
losfer
 Posted: Tue Sep 14, 2010 7:33 am |
if you have a external 4 wire ignitor and a 57b1 dizzy with a red wire and a white wire , can you check the wire clours at ecu pinouts b3 and b16 (which is directly above b3) . looking at the ecu with plugs plugged in , its the second plug , and the third wire in from the left (b3) and the one above it (b16).
the manual lists one as cas positive and one is cas negative , although its not absolutely critical on the polarity , i need to know the colours..
thanks
Dave
losfer
 Posted: Thu Sep 16, 2010 10:55 am |
pretty keen to know the answer guys...
using the factory ecu its pretty critical as it uses the falling edge from the wave to ignite .
im trying to wire up a aftermarket ecu , and knowing which one is postive will save time in the config of the ecu .. eg , whether it will be rising or falling edge ignition.
the ecu pinout says that one is the positive and one is the negative , the wiring diagram doesnt show wire colours , it just shows that both wires go back to the ecu..
atari4x4
 Posted: Thu Sep 16, 2010 11:01 am |
SV420 J20a any good to you?
losfer
 Posted: Thu Sep 16, 2010 11:31 am |
not really , the sv420 uses a completely different setup .. it doesnt even have a dizzy ! thanks for trying though .
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Thu Sep 16, 2010 11:35 am |
Sorry, but both mine have internal igniter
_________________ 2013 GV 1998 SV420 ute
waimser
Joined: Wed Sep 15, 2010 10:24 am Posts: 63 Location: SA
 Posted: Fri Sep 17, 2010 3:04 pm |
Any pics of what you what you the item in question? Most of what you said is jibberish to me but if I can see what im supposed to be looking at I may be able to help.
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 322 guests
