https://auszookers.com/forum/
favour from vitara owners if possible
https://auszookers.com/forum/viewtopic.php?f=5&t=15111
Author:  losfer [ Tue Sep 14, 2010 7:33 am ]
Post subject:  favour from vitara owners if possible
if you have a external 4 wire ignitor and a 57b1 dizzy with a red wire and a white wire , can you check the wire clours at ecu pinouts b3 and b16 (which is directly above b3) . looking at the ecu with plugs plugged in , its the second plug , and the third wire in from the left (b3) and the one above it (b16).
the manual lists one as cas positive and one is cas negative , although its not absolutely critical on the polarity , i need to know the colours..
thanks
Dave
Author:  losfer [ Thu Sep 16, 2010 10:55 am ]
Post subject:  Re: favour from vitara owners if possible
pretty keen to know the answer guys...
using the factory ecu its pretty critical as it uses the falling edge from the wave to ignite .
im trying to wire up a aftermarket ecu , and knowing which one is postive will save time in the config of the ecu .. eg , whether it will be rising or falling edge ignition.
the ecu pinout says that one is the positive and one is the negative , the wiring diagram doesnt show wire colours , it just shows that both wires go back to the ecu..
Author:  atari4x4 [ Thu Sep 16, 2010 11:01 am ]
SV420 J20a any good to you?
Author:  losfer [ Thu Sep 16, 2010 11:31 am ]
not really , the sv420 uses a completely different setup .. it doesnt even have a dizzy ! thanks for trying though .
Author:  Fatzook [ Thu Sep 16, 2010 11:35 am ]
Sorry, but both mine have internal igniter :cry:
Author:  waimser [ Fri Sep 17, 2010 3:04 pm ]
Any pics of what you what you the item in question? Most of what you said is jibberish to me but if I can see what im supposed to be looking at I may be able to help.
