It is currently Fri Oct 30, 2026 12:51 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
Post Posted: Wed Sep 15, 2010 2:04 am
hi people just wondering what work goes into welding the rear diff, its a 1.3 WT if that makes a diffrance
Vehicle: 4wd
Post Posted: Wed Sep 15, 2010 2:06 am
NOT like that
Watch out or you'll get sued.
Post Posted: Wed Sep 15, 2010 2:09 am
hahaha yer i know that much
Post Posted: Wed Sep 15, 2010 2:22 am
i think royce should make the 'search' title the biggest thing you can see. :roll:
The problem with rear sierra centres (some older fronts also) is that they are fully closed. You have to pull the carrier out of the centre, and pull it apart, and weld the gears in there, but make sure the 4th side gear lines up nice, and the top plate can be bolted back on.
There is another way to wled them also, can't find link, but i have done it and they click and act abit weird.
Otherwise buy a spool, or other type of shit-wong or air locker that replaces the centre if you want to swap it to an open diff again.
Depends how handy you are at getting the backlash back to stock also.
Post Posted: Wed Sep 15, 2010 2:23 am
Joeblow teh new grimbo?
Post Posted: Wed Sep 15, 2010 2:53 am
ok so no buying all new shit for welded diff its just whats already in the centre.
Post Posted: Wed Sep 15, 2010 2:57 am
Found this pic courtesy of want33s in another thread....
Does that give you an idea?
Should lock things up real nice for ya...
I want my old sig back :(
Post Posted: Wed Sep 15, 2010 3:07 am
Good one, how about the same pic found at the top of this thread :roll:
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Wed Sep 15, 2010 3:22 am
I had to read that 3 times.
Welded diff, is ..a welded diff. No other mods except for weld...
Post Posted: Wed Sep 15, 2010 3:39 am
haha sorry, ok lets see how many centres i go through before i get it right
Post Posted: Wed Sep 15, 2010 3:40 am
I don't see any other pics in this thread....
Post Posted: Wed Sep 15, 2010 3:47 am
nice tech, dont weld it like this. :roll:
Post Posted: Wed Sep 15, 2010 3:50 am
was this the thread?
want33s wrote:
If you must weld a diff (which I wouldn't recommend) then do it this way...
http://www.island4x4.com/4x4tech/axle/weldeddiff1/
Post Posted: Wed Sep 15, 2010 3:56 am
stockman wrote:
NOT like that
Lil Foot!
Post Posted: Wed Sep 15, 2010 4:19 am
JrZook wrote:
stockman wrote:
NOT like that
I still can't see the pic, though I can see the link in the quoted text...
Must be the shitty filters on the work network....
Post Posted: Wed Sep 15, 2010 4:21 am
I've done them this way a few times. Never had an issue 8)
Post Posted: Wed Sep 15, 2010 4:28 am
www.island4x4.com/4x4t...ldeddiff1/
on a scale of 1-10 how hard is it to do this
Post Posted: Wed Sep 15, 2010 4:30 am
Depends... Do you know how to use a welder?
If so, easy.
If not, hard...
Post Posted: Wed Sep 15, 2010 4:31 am
how hard is it to do it this way
Post Posted: Wed Sep 15, 2010 4:32 am
sorry for the double post,
Post Posted: Wed Sep 15, 2010 4:41 am
[/quote]
IMO this is the best way to weld a diff. if you get the shits with it you can change side gears rather than f*$%ing a whole diff centre
Post Posted: Wed Sep 15, 2010 4:50 am
so this just locks the back wheels so they both spin at the same speed. so it will keep pushin if one of the back wheels are off the ground.
Post Posted: Wed Sep 15, 2010 4:52 am
Yep.
It will also keep the wheels spinning at the same speed on the road when you go round corners, so it will increase tyre wear, the tyres will skip a bit on hard lock, and it'll sqeak and squeal in car parks.
If you can live with that then go for it...
Post Posted: Wed Sep 15, 2010 4:57 am
thanks everone for your help i will consult the fabricator (dad) and see what he rekons, ill keep ya posted
Post Posted: Wed Sep 15, 2010 6:48 am
Dads normally dont like the idea. :lol:
I welded my side gears as per the last pic, they ended up ratcheting, wearing out the welds, then will eventually smash. On 33's.
0
Post Posted: Wed Sep 15, 2010 6:50 am
0
use a higher tensile rod or filler wire next time.
Post Posted: Wed Sep 15, 2010 7:11 am
That seems like a pretty good option. I've never liked the idea of welded diffs but this is a pretty good compromise.
Post Posted: Wed Sep 15, 2010 7:15 am
i never knew could be done the way in that other pic just doin the side gears.Its kinda cool,ill try it one day and as you say saves wrecking a hole centre
i normally belt bolts in between the 4 spider gears,fill the crap out of it,then side gear back on,some minor weld again and bolt it all back up.ive broken 2 due to not enough weld but i suspect i have a 3rd one on its way out now after nearly 2 years
Vehicle: 1987 sierra tray back buggy
Post Posted: Wed Sep 15, 2010 7:42 am
on this topic are the side gears used in the nt and wt diffs and all the different ratios out there the same
as in could i use the side gears out of a wt rear with a 3.7 or what ever ratio it is in an nt diff center with a 4.1 ratio?
Users browsing this forum: No registered users and 161 guests
