It is currently Sat Oct 31, 2026 5:44 pm
Post Posted: Thu Sep 16, 2010 7:14 am
well my car is pulling to the left when i put the brake on ???? check all brakes they are fine cleand them ou bleed the brakes and still when i stab the brakes my left front locks up but my right dosent i run front hilux diff bundara rear could it be the master cylinder not pushhing fluid to the right can some body help all my tyers spin free and they are on the right direction :roll:
Post Posted: Thu Sep 16, 2010 7:29 am
king pin??
Post Posted: Thu Sep 16, 2010 7:33 am
Are you still running the Sierra master? Are all the caliper pots free? It could be siezed on the right
Post Posted: Thu Sep 16, 2010 7:52 am
Chopz wrote:
king pin??
im gunna sound dum wherea the king pin mind blank :?
Post Posted: Thu Sep 16, 2010 7:54 am
yes still runing sierra master what would be a good biger 1 :lol:
Post Posted: Thu Sep 16, 2010 7:55 am
will check to c if they are but when i bleed them they moved :?:
Post Posted: Thu Sep 16, 2010 8:05 am
I believe you can use a Subaru one. It has been discussed here somewhere...
Vehicle: Jeep
Post Posted: Thu Sep 16, 2010 4:43 pm
Sounds a bit like a non functional wheel cylinder to me... :wink:
Post Posted: Fri Sep 17, 2010 12:49 am
my mate had a similar problem on his pootrol.
when he braked it will pull left.
the mechanic told him its just the camber in the road :roll: :roll:
fuck there are some real douches out there
turned out it was a seized king pin
Post Posted: Fri Sep 17, 2010 1:00 am
I had the same problem on my sierra but it would come and go. Turned out to be one of my guides on the L.H front caliper was gummed up. Every so often it would bind and the caliper would skew and snatch the rotor. When I pulled it apart the brake pads on that side looked a bit like door wedges, they were literally on the metal one end and meaty the other. Maybe yours has started to do this?
Vehicle: SJ80, SE416
Post Posted: Fri Sep 17, 2010 1:07 am
Better fix it if this starts to happen. I had this happen when the caliper slides were stuffed from mud getting in the seals. I fixed it after the caliper threw the pad out onto the road while I was driving. There was a loud noise, then the brake pedel went to the floor and then I had no brakes!!!
Post Posted: Fri Sep 17, 2010 2:14 am
The Hilux calipers don't have slide pins
Post Posted: Fri Sep 17, 2010 2:24 am
I would be checking to make sure that none of your pistons are seized, it won't be slides like others have mentioned above as the hilux run a 4 piston calliper setup, then i would be checking king pin bearings.
weaves
Post Posted: Fri Sep 17, 2010 5:53 am
weaves wrote:
I would be checking to make sure that none of your pistons are seized, it won't be slides like others have mentioned above as the hilux run a 4 piston calliper setup, then i would be checking king pin bearings. weaves
king pin bearings are they the ones witch are on top and botom of ur hub are they im no mecanic but no where evry thing goes :roll:
Post Posted: Fri Sep 17, 2010 6:03 am
They are the bearings in the knuckles that allow the hubs to swivel so the wheels can steer. You will see 4 bolts on a small plate top and bottom of the knuckles, these are your bearings.
Post Posted: Fri Sep 17, 2010 6:26 am
ahh mite be time for a rebuild in the fron diff arrg thanks heaps evry one ilee try these options
Post Posted: Fri Sep 17, 2010 8:17 am
if you want a quote on a rebuild kit, PM me.
Post Posted: Sat Sep 18, 2010 6:41 am
u were rite sized cazliper fixd it now all good thanks heaps evryone 8)
Post Posted: Sat Sep 18, 2010 7:11 am
Sound like you didnt clean all the brakes.
Vehicle: Jeep
Post Posted: Sat Sep 18, 2010 7:20 am
Shit 8O i was right 8O :wink: :lol:
Post Posted: Sun Sep 19, 2010 8:00 am
i di but didnt c the seazd pot under the dust cover :lol:
Users browsing this forum: No registered users and 404 guests
