| pulling to the left hard https://auszookers.com/forum/viewtopic.php?f=5&t=15160 |
| Author: | scotteastham [ Thu Sep 16, 2010 7:14 am ] |
| Post subject: | pulling to the left hard |
well my car is pulling to the left when i put the brake on ???? check all brakes they are fine cleand them ou bleed the brakes and still when i stab the brakes my left front locks up but my right dosent i run front hilux diff bundara rear could it be the master cylinder not pushhing fluid to the right can some body help all my tyers spin free and they are on the right direction |
| Author: | Chopz [ Thu Sep 16, 2010 7:29 am ] |
| Post subject: | Re: pulling to the left hard |
king pin?? |
| Author: | Scrawny [ Thu Sep 16, 2010 7:33 am ] |
Are you still running the Sierra master? Are all the caliper pots free? It could be siezed on the right |
| Author: | scotteastham [ Thu Sep 16, 2010 7:52 am ] |
Chopz wrote: king pin?? im gunna sound dum wherea the king pin mind blank |
| Author: | scotteastham [ Thu Sep 16, 2010 7:54 am ] |
ScrawnC wrote: Are you still running the Sierra master? Are all the caliper pots free? It could be siezed on the right yes still runing sierra master what would be a good biger 1 |
| Author: | scotteastham [ Thu Sep 16, 2010 7:55 am ] |
will check to c if they are but when i bleed them they moved |
| Author: | Scrawny [ Thu Sep 16, 2010 8:05 am ] |
scotteastham wrote: ScrawnC wrote: Are you still running the Sierra master? Are all the caliper pots free? It could be siezed on the right yes still runing sierra master what would be a good biger 1 I believe you can use a Subaru one. It has been discussed here somewhere... |
| Author: | MacDaddy [ Thu Sep 16, 2010 4:43 pm ] |
Sounds a bit like a non functional wheel cylinder to me... |
| Author: | Chopz [ Fri Sep 17, 2010 12:49 am ] |
my mate had a similar problem on his pootrol. when he braked it will pull left. the mechanic told him its just the camber in the road fuck there are some real douches out there turned out it was a seized king pin |
| Author: | sleeperzook [ Fri Sep 17, 2010 1:00 am ] |
I had the same problem on my sierra but it would come and go. Turned out to be one of my guides on the L.H front caliper was gummed up. Every so often it would bind and the caliper would skew and snatch the rotor. When I pulled it apart the brake pads on that side looked a bit like door wedges, they were literally on the metal one end and meaty the other. Maybe yours has started to do this? |
| Author: | Reubs [ Fri Sep 17, 2010 1:07 am ] |
sleeperzook wrote: When I pulled it apart the brake pads on that side looked a bit like door wedges, they were literally on the metal one end and meaty the other. Maybe yours has started to do this?
Better fix it if this starts to happen. I had this happen when the caliper slides were stuffed from mud getting in the seals. I fixed it after the caliper threw the pad out onto the road while I was driving. There was a loud noise, then the brake pedel went to the floor and then I had no brakes!!! |
| Author: | Scrawny [ Fri Sep 17, 2010 2:14 am ] |
The Hilux calipers don't have slide pins |
| Author: | weaves [ Fri Sep 17, 2010 2:24 am ] |
I would be checking to make sure that none of your pistons are seized, it won't be slides like others have mentioned above as the hilux run a 4 piston calliper setup, then i would be checking king pin bearings. weaves |
| Author: | scotteastham [ Fri Sep 17, 2010 5:53 am ] |
weaves wrote: I would be checking to make sure that none of your pistons are seized, it won't be slides like others have mentioned above as the hilux run a 4 piston calliper setup, then i would be checking king pin bearings. weaves king pin bearings are they the ones witch are on top and botom of ur hub are they im no mecanic but no where evry thing goes |
| Author: | Scrawny [ Fri Sep 17, 2010 6:03 am ] |
They are the bearings in the knuckles that allow the hubs to swivel so the wheels can steer. You will see 4 bolts on a small plate top and bottom of the knuckles, these are your bearings. |
| Author: | scotteastham [ Fri Sep 17, 2010 6:26 am ] |
ScrawnC wrote: They are the bearings in the knuckles that allow the hubs to swivel so the wheels can steer. You will see 4 bolts on a small plate top and bottom of the knuckles, these are your bearings. ahh mite be time for a rebuild in the fron diff arrg thanks heaps evry one ilee try these options
| Author: | weaves [ Fri Sep 17, 2010 8:17 am ] |
if you want a quote on a rebuild kit, PM me. |
| Author: | scotteastham [ Sat Sep 18, 2010 6:41 am ] |
MacBear wrote: Sounds a bit like a non functional wheel cylinder to me... u were rite sized cazliper fixd it now all good thanks heaps evryone |
| Author: | BlueSuzy [ Sat Sep 18, 2010 7:11 am ] |
scotteastham wrote: check all brakes they are fine cleand them ou bleed the brakes
Sound like you didnt clean all the brakes. |
| Author: | MacDaddy [ Sat Sep 18, 2010 7:20 am ] |
scotteastham wrote: MacBear wrote: Sounds a bit like a non functional wheel cylinder to me... u were rite sized cazliper fixd it now all good thanks heaps evryone Shit |
| Author: | scotteastham [ Sun Sep 19, 2010 8:00 am ] |
BlueSuzy wrote: scotteastham wrote: check all brakes they are fine cleand them ou bleed the brakes Sound like you didnt clean all the brakes. |
