| Diff gear swap Brisbane https://auszookers.com/forum/viewtopic.php?f=5&t=15187 |
| Author: | redzook91 [ Fri Sep 17, 2010 12:22 pm ] |
| Post subject: | Diff gear swap Brisbane |
Right, alloy diff went south for the winter as I knew it would, now I need to get the 5.12's swapped from it into the steel one. Anyone know someone that they can refer me to to get that done? I got the original ones from the steelie pressed out at a place just behind archerfield airport but it was dear as poison. I'm hoping to get it done for around $40 or so but am i just being a cheap bastard? Any help would be much appreciated. Cheers, Red |
| Author: | atari4x4 [ Fri Sep 17, 2010 1:08 pm ] |
| Post subject: | Re: Diff gear swap Brisbane |
$40 how much did they charge you to remove the one from the GV diff, expect to pay a lot more than that.... |
| Author: | redzook91 [ Fri Sep 17, 2010 1:12 pm ] |
Cost me 60 but I thought that was a relative pricing thing. It seemed like a lot for just pressing out the pinion gear. Probably should go back to those guys then What is the usual? |
| Author: | atari4x4 [ Fri Sep 17, 2010 1:27 pm ] |
setting up a diff isn't something to be taken lightly, considering ARB charge $330+ just to fit a locker without removing the pinion. seeing you need the pinion fitted to the steel carrier, pinion depth set, then getting a good meshing pattern can take a while, then they need to set the backlash, new bearings would be the smart thing to do while its apart, i'd be budgeting alot more that $60... |
| Author: | redzook91 [ Fri Sep 17, 2010 1:30 pm ] |
| Author: | atari4x4 [ Fri Sep 17, 2010 1:58 pm ] |
my diff was done by a "diff specialist" & it was over $500 to build the steel diff up with the 5.12's with new bearings, seals & fit the locker. EDIT: & the bloody thing still failed |
| Author: | redzook91 [ Sat Sep 18, 2010 10:43 am ] |
Anybody? No? Dust? |
| Author: | 5ierra [ Mon Sep 20, 2010 1:19 am ] |
I'm going to do some calling around today, i'll let you know how i got... Difference being i'm supplying the parts. |
| Author: | Fatzook [ Mon Sep 20, 2010 1:29 am ] |
5ierra wrote: I'm going to do some calling around today, i'll let you know how i got...
Difference being i'm supplying the parts. You have a PM |
| Author: | Fatzook [ Mon Sep 20, 2010 1:31 am ] |
redzook91 wrote: Anybody? No? Dust?
PM'd |
| Author: | redzook91 [ Mon Sep 20, 2010 1:43 am ] |
5ierra wrote: I'm going to do some calling around today, i'll let you know how i got... Difference being i'm supplying the parts. Awesome.... Fatzook wrote: redzook91 wrote: Anybody? No? Dust? PM'd .....and Awesome |
| Author: | tanshi [ Mon Sep 20, 2010 1:58 am ] |
i payed around 400 to get mine rebuilt. |
| Author: | Fatzook [ Mon Sep 20, 2010 2:04 am ] |
tanshi wrote: i payed around 400 to get mine rebuilt.
I paid half that for 2 |
| Author: | tanshi [ Mon Sep 20, 2010 2:16 am ] |
mother F$%&*%&% hehe |
| Author: | tombutt [ Mon Sep 20, 2010 5:33 am ] |
i paided zero dollars and zero cents actually that reminds me have to fix them up for the seal |
| Author: | Fatzook [ Mon Sep 20, 2010 6:13 am ] |
tombutt wrote: i paided zero dollars and zero cents actually that reminds me have to fix them up for the seal
Pay peanuts, get monkeys. |
| Author: | tombutt [ Mon Sep 20, 2010 6:22 am ] |
my diff is fine my mate did it for me he does them all the time at his work |
